My MTX thunder 502x was working fine and know the amp light is flashing yellow and red. i have checked the fuses and disconnected the power and ground and reconnect, same problem. it continues even when i disconnect the wires from the deck.
What is the electrical system in the different car like?You may need to get a secondary battery for that amp.Also ceck your in line fuse,it may need to be larger.Sounds to me like you either do not have enough power,or a ground is not connected.
could be the wires is bad or someplace the power wire is grounding out or the fuse or fuses is blown. or could be not enough voltage but highly doubt it.
The light flashing usually means there is a short somewhere. Check your wires to make sure there are no slices and are touching. Also check to make sure you have your remote wire hooked up.
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Hello tonytone54,
The ground should go directly to the vehicle frame, never through a cap, fuse, or anything else. Also, if you are connecting positive through a cap, make sure that you charge the cap before connecting it.
Hope this helps.
Unfortunately I think you need to get it repaired or replaced .When a protection light will not turn off it is generally caused by an internal short and needs one or more replacement parts for it to come alive again.
-Dynami
