The property was transferred to me in November 2013 ,Went to apply for a prepaid meter and was told there was a prepaid meter installed in 2009.When i moved in there was no meter on the property.I was informed i would be charged for meter tampering.The Muncipality has not billed the property for electricity since 2009 as one would buy tokens and load electricity.I am not sure how long the electricity has not been paid and who would be responsible for those years.
Ecolec only MAKE meters, whomever supplies your power buys them, fits them and takes the money. Look for a sticker on it, or ask a neighbour. There may also be a message on the meter display telling you how to refill.
Electricity.co.zahttps://www.electricity.co.za
Buy Prepaid Electricity Online 24 hours a day. We support over 100 Municipalities and Sub metering Companies country wide, Example: Eskom, Tshwane, ...
Token Processing Failed Error. Contact your Utility company, the owner of the meter.
Conlog Meters (old): EEEE - Invalid Token This is caused by any of the following: The meter serial number on the token does not match the physical meter number on the meter. The UIU will then remain on protocol 2 and not detect the WMD when you try to search again.)
Geeky Nigeriahttps://geeky.com.ng > Technology
Mar 20, 2022 - EEEEEEE. This means "Token processing failed". It is displayed when the token is accepted by the meter but cannot be processed. It may be ...
Conlog Meter=04xxxxxxxxx. Put the meter number and press "enter" (meter will display succeed). Step 2: Confirm you have loaded your meter activation token ...
People also ask
How do I load my token on Conlog prepaid meter?
How do I load my electricity token on Conlog?
Conlog Meter, Input 009 & press enter and the current unit on the meter will display. EDMI Meter: Single Phase: Input 10 & press enter and the current unit on the ...
hi robbin,
when you purchase a new phone, and if you are using a prepaid sim card or you applied for a prepaid account, then the reason why you are getting a prompt no airtime is because you don't have enough credits on your account to be able to make a successful call.
you need to reload your account by buying a prepaid card or thru internet banking transferred to your mobile phone number (if your carrier supports this)
or your account may not be active yet, you may contact your service provider for them to activate your account.
thanks,
nina
That can be caused buy a number of things but it being November in all i would say to check for condensation in your fuel lines, I personally would not recommend mixing the carb cleaner with the gas but instead make sure lines are free of condensation, proceed with refueling with mid grade gas or regular doesn't really matter, and while having a friend or family member start the motor spray the carb cleaner a little at a time into the carburetor and it should give it that start boost it needs to get running and also check the chock and make sure the air filter is not clogged up.. Hope this helps.. Thanks
