Question about Microsoft Windows XP Professional for PC
Cannot delete ESET folder from Program files. the program already uninstalled but left this folder in my Program files folder. error message: "You need permission to perform this action.'' OS - Vista Business. Tried to turn off UAC, take ownership.
  • 1 more comment
  • xrayrentg525 Jun 05, 2009
    Thank you Sir. i've learned a very nice trick from you. It worked.
    But it was done by another method on another PC. I took ownership and tried to delete in normal mode. No success. But in Safe mode it's done.
  • N R Green
    N R Green Mar 26, 2014
    I will try in safe mode, thanks
  • Anonymous Mar 30, 2014
    A friend was helping m3 on my laptop who is in college for computer programming and after he left I get messages that say I have to inherit permission back so I think he is spying on me how do I get him off I got a vista basic service pack 2 I am lost and don't know what to do help
    President:
  • 688 Answers
Apparently MS in their infinite wisdom decided that in vista they would take the power away from the user and remove the administrator from the equation.
So no matter how many thing your try in the user accounts you will not get full admin rights.
but here is a reg hack that worked for me real well. I am running windows vista home basic
Click Start and Run type in regedit and enter
your now at the registry editor.
click and expand HKEYLOCALMACHINE
go down and click SOFTWARE
click MICROSOFT
click WINDOWS
click CURRENTVERSION
click POLICIES
click SYSTEM
you will see the registry entries to the right
right click in the white area and select new DWORD
Name it "EnableLinkedConnections" and enter
Right Click on EnableLinkedConnections and choose MODIFY change the Data Value to "1"
Save and exit Registry Editor
Reboot your computer and try deleting the folder you wanted to again.
WARNING:
Using this reg edit you are changing your registry and could develop problems if you don't do it correctly. Be Warned and do some research prior if you need to understand registry editor.
Posted on Jun 04, 2009
I am failed to delete by this process.
Posted on Mar 03, 2012
How do I uninstall knctr, a tv app, from my computer for free?
Find the program in the Program Files folder. Right click on the program folder and then select delete from the drop down menu. If you get an error message make sure the program is not running. If there's a small icon for the program on the bottom of the screen, click on it to close it first. Then retry the steps above to delete the file.
Nov 21, 2015 | Computers & Internet
Cannot uninstall Belkin. The uninstall file could not be found
this thing happens when you delete the folder in which your files for the program are stored.
or in case you delete the uninstall.exe file.
the program has already been removed from your hard disk, what remains is just the entry in windows registry.
when you uninstall a program, the registry entry is also deleted, so its recommended to always uninstall the program rather simply deleting the program folder.
Nevermind, in your case you can delete the program folder in case you still have it, and the windows entry can be fixed by any registry fixing software like 'Advance System Optimizer'
Oct 10, 2013 | Computers & Internet
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
When I go on-line, I receive this message ''RUNNER FILE ERROR''
Probably was uninstalled already. 2 solutions:
1.Right click on My Computer select Explore
Select C; click explore again
Select Program Files folder, explore
Find the kodak Program and Delete
the folder.
2. Go Start y type MSCONFIG in RUN or Search
hit enter, a window will appear on
your screen in the tab "STARTUP"
un-check the line that contents
Kodak application. Press OK and
Re-Start the computer.
Apr 10, 2010 | Computers & Internet
Application error occuring to install or remove yahoo massenger?
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Failure to initialize error message persisting? try this download site
http://download.yimg.com/ycs/msg/dl/msgr10/us/ymsgr1000_525_us.exe
Jan 09, 2010 | Yahoo Messenger
Yahoo Messenger Initializing Prob
Check
Failure to initialise error message ? try this download site
Jan 07, 2010 | Yahoo Messenger
Error mesg while loading yahoo messenger 10
Check
Download 'ccleaner' and run it through a couple of times,using the factory settings and the'Run Cleaner' control until 0 bytes are available for cleaning
Run the 'Registry' from the left hand toolbar but 'Save' any changes before repairing
Dec 24, 2009 | Yahoo Messenger
Error message: installation needed check firewall
Check
How to completly remove ESET
Hi there.
Download CCleaner, install it and use the cleaner to delete temp and temp internet files, then you want to clean the registry, when you click on fix selected issues make sure you back them up to the registry, keep on scanning for issues and fixing them until no more issues are found, restart the PC and try to manually delete the left over ESET folders.
Post back if you still can't get rid of the old folders.
Good luck and thanks for using FixYa!!
Mar 13, 2009 | Computers & Internet
I recently uninstalled Printmaster Silver 12 (temporarily needed all the hard drive space I could get), and now I am trying to reinstall. The install process gets to the registration phase, gives the...
Most programs like this leave behind "junk" files or folders with some information in them.
Try uninstalling it again, then go to the C:\ drive and look for any folders that it might have left behind.
Then go to Start do a search for PMUSERS.dat and delete it.
Jan 16, 2009 | Broderbund Printmaster Silver 12.0
Microsoft Windows XP Professional for PC Logo
2,031 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
