Question about Amana ACD106R Wall/Window Air Conditioner
Central air condtioner making beeping noise!
When i turn on the central air condition, it starts making loud beeping noise that sounds like door buzzer every couple minutes! the noises go away once i turn off the ac. does anyone know what the problem is? thanks!!
  • Bryan Jones May 11, 2010
    is this noise indoor or outdoor, and like a BEEP BEEP or just a similiar sound?
  • 158 Answers
It means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Posted on Jun 04, 2009
  • 518 Answers
SOURCE: water keeps leaking from central
It's supposed to do that. There should be a drain line on it to direct the water to drain. That line may be plugged up, you'll have to check it out.
Geno
Posted on Aug 02, 2008
  • 116 Answers
SOURCE: My central heating and air-conditioning unit completely stopped working - the model# is e2eb-015hb
manually bump the contactor whare the main power comes in with a insulated object isf unit starts then check for call from stat on stat wire from common to red 24v ac transformer good or see if indoor fan comes on next check call from stat common to yellow 24 v then look for low psi switch to see if it has it locked out could be low on gas
Posted on May 09, 2009
bobicehouse
  • 1524 Answers
SOURCE: Cost to replace a home central AC compressor in MA
With the phase out of R22, it is suggested to replace the system with a more energy efficent R410A system.
Posted on Apr 23, 2009
  • 30 Answers
SOURCE: Can somebody help,why is my Central AC blows
Most heat pumps have an auxillary heat. Many are electric auxillary heat with a heat strip in the air handler. A common malfunction is for the electric auxillary heat to operate when the heat pump is set on cool. To confirm this, locate the conductor that runs from the heat sequencer to the connection on the heat strip. You will see this on the top section of the air handler. Use the clamp on part of the amp meter over that wire. If the thermostat is set on cool and the heat strip is drawing amps, it means the heat is coming on while the heat pump is set on cool. There is usually one or two causes for this, either the sequencer is bad or there is low voltage wires usually behind the thermostat or in the air handler closet that are touching that shouldn't be touching.
If this is not the case, if its not a problem of where the heat is coming on with the air conditioner, it could be a case of the reversing valve malfunctioning. The way a heat pump works is it reverses the flow of the refridgerant. For instance, many heat pumps the reversing valve is activated in cool. That would mean that there is a low voltage circuit that activates the reversing valve when the heat pump is in cool. I'm not sure what model/brand your heat pump is, Goodman and Janitrol for instance, the heat pump reversing valve is activated in cool. In any case, if the reversing valve is not operating properly, when the air conditioning is set to cool it will actually be heating. Or you could set it to heat and it may actually be cooling instead of heating. Please check these two items first and if you have any further questions, please let me know. Especially if you know of any additional problems like the evaporater is icing up or if the air handler fan is not operating when it should.
Posted on Aug 31, 2009
Testimonial: "Thank you for your time! "
  • 1274 Answers
SOURCE: schematic diagram of central air conditioning
Several types out there. 99% of them use the same basic wiring.
Red is power from transformer to t'stat. Sometime there is a wire for common from transformer to t'stat too, but not always.
While is for heat. Green is for fan. Yellow is for cooling.
These 4 to 5 wires go on the terminals that are maked with letters: C=common, RH/RC is for power, W=heat, Y=cooling, G=fan.
In most cases, 2 wires from the indoor unit will go to the outdoor unit to power it for cooling. Usually connected to the yellow wired, Y terminal and common or grounded to the unit if the transformer is done in the same fashion.
If you have a heat pump, totally different animal and different wiring too.
Hope this helps you. Good Luck.
Posted on Dec 20, 2009
Hi i have a novotronic T560C there is a loud noise that starts after a few mins and moisture on the drum door when I put in dry clothes
Buzzer sounds when the drum turns during the
intermittent anti-crease action period. When the programmable switch is set on the following settings: Normal+, Normal, Hand iron
Refer to page 4 of the user's / owner's manual
Dec 03, 2013 | Dryers
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
I need help with a buzzing sound in my air conditioner.
It is probably the compressor humming. They can make some funny noises especially on start for a while. If the unit is not cooling it may be the start capacitor or the comressor may be locked up.
Jul 19, 2010 | Goodman CLQ36AR49 Air Conditioner
Whenever I turn on my air conditioner, my car makes a roaring or rubbing noise. What is it?
Sounds like the clutch in the compressor which would usually be in the front lower portion of the engine on a pulley on the front of engine (passenger side on front wheel drive cars - and tubes are connected to it.  When engine is off spray with some lube but not on belt - allow to drip of for couple minutes.
Try that couple times and start car in between times using the air conditioning.  Not sure if you can replace the clutch unit or have to replace the compressor as a unit which would lose the Freon or R2 or whatever the new stuff is called now...
Hope that helps.
East Coast Canada Rocks!!
Jun 11, 2010 | 1998 Chevrolet Cavalier
Carrier A/C making buzzer noise every 6 minutes.
Probably the contactor, they have a coil that sometimes buzzes, after the contacts become pitted and no loger pull together like they are supposed to. It could also be a voltage problem from the transformer that is causing it, but I would bet on the contactor. Get it fixed quickly as a voltage drop across the contactor can be the demise of you compressor!
Jul 13, 2009 | Heating & Cooling
Bmw air injection pump problem...HELP!
sounds like the secondary air pump has water contamination. If you unplug the connector for the air pump, and check it on cold start, did the noise go away? If the pump is bad, you need to replace the secondary air valve. Sounds like maybe it is contaminated and not seating fully.
Feb 18, 2009 | 2000 BMW M5
Recently bought a 1996 mitsubishi galant S a couple of weeks ago & the interior light was'nt working. Then it started working sometimes then it quit working again. The buzzer when the door was open...
Sound's like you have some sort of a short or an open, somewhere, i would first check your fuse box,
in your engine and in your dash with a test light. make sure all fuses are working, if you had an open or short it could be possible you blew various fuses with a certain surge of power..
Second.. if you have an aftermarket sterio and all said before turns out alright. then i would pull out and check the wiring in the sterio and all surrounding it, one could have been rubbing up on another bare wire or ground out.
good luck..
Oct 26, 2008 | Mitsubishi Galant Cars & Trucks
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Amana ACD106R Wall/Window Air Conditioner Logo
5,414 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
