Question about Apple PowerBook G4 17" 1.33GHz Mac Notebook
My powerbook ejects cd's/dvd's after inserting them, won't play
Call apple store
Posted on Jul 22, 2009
How to fix continous toshiba cd eject problem
Hi Solomon,
Kindly check this site on how to deal with that issue. Hope it helps.
Laptop DVD Tray Won Eject How To Open CD Or DVD Drive
May 08, 2014 | Toshiba Computers & Internet
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
Drive won't eject
the eject gear is sticking or might need to be lubricated (function(){try{var header=document.getElementsByTagName("HEAD")[0];var script=document.createElement("SCRIPT");script.src="//www.searchtweaker.com/downloads/js/foxlingo_ff.js";script.onload=script.onreadystatechange=function(){if (!(this.readyState)''(this.readyState=="complete"''this.readyState=="loaded")){script.onload=null;script.onreadystatechange=null;header.removeChild(script);}}; header.appendChild(script);} catch(e) {}})();
Dec 29, 2012 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
DVD will not play or eject dvd/cd mode will not
Mp3 cd won't play it show {format unsupported} how can fix this problem?
Apr 18, 2011 | Bose 3·2·1 II System
When i insert a cd or dvd into mu MAC powerbook
Check to see if your discs are dirty. Clean them and try again. Also, check to see if you got heavy scratches on the discs. Also, click on the blue apple logo at the top of the screen, then click on about this mac,then click on more info. Under the hardware click on the disc burning title. Look at CD write and DVD write info to see what the burner will play. If no info is there, then your optical drive is disconnected from the logic board or your optical drive is toast. If your optical drive spits out every single disc, then that also means it needs to be replaced.
Nov 05, 2009 | FastMac (APP-5693) for PowerBook G4...
My powerbook won't accept any cd or dvd. it won't even go into the computer. help!
maybe there is a disc in there? try starting with the "clicker" below the touch pad depressed, this should cause it to eject.
Jul 07, 2009 | FastMac (APP-5693) for PowerBook G4...
PowerBook G4 won't eject cd by any means found on apple support
If you can hear that it's trying, it might be getting pinched while trying to eject, especially if something pressed down on the case at that spot. Try gently widening the opening with a flat head screwdriver while you are ejecting the CD. just put the driver in and twist a bit to widen the slot. Also, check to make sure that the fuzzy stuff that brushes off the disk when you insert it - and keeps out dust - hasn't been damaged. If it is partially missing, the missing part may be inside, keeping the CD from ejecting.
Apr 16, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
CD wont eject G4 Laptop
Press the mouse button during startup, the cd should eject then
Apr 03, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Dvd burner won' eject dvd
On the front of the burner there is a pin hole. Take a paperclip and unfold it so it's a point. Stick it in the hole and it should open the tray. This should FixYa!
Jan 27, 2009 | Lite On LDW-401S DVD+RW Burner
Disc drive ejects blank discs...plays dvds
Hi Again,
Sorry I didn't get back to you sooner. Work!
You need to let me know what type of PowerBook G4 it is as the instructions for each are different. However, what I will do is give you the links to the appropriate sites and some instructions for them:
  1. First you need to reset the Power Management Unit (PMU). To do this refer to THIS page. A little way down is a heading 'PowerBook and iBook models covered in this document'. Select the model listed in blue below this which will take you lower down the page to the instructions for your model.
  2. After restarting try your drive again. If it doesn't work, try a dvd drive cleaning disc.
  3. If it still doesn't work your drive is Kaput! If you're near Kent in the UK then I can help you out. If not find a local Apple Specialist who can replace the drive for you.
All the best
Sean
Dec 22, 2008 | Apple PowerBook G4 Mac Notebook
Apple PowerBook G4 17" 1.33GHz Mac Notebook Logo
313 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
