Question about White Sewing 1415 Mechanical Sewing Machine
Not making stitches not catching bobbin thread and not forming stitch cant sew
  • 26 Answers
SOURCE: The bottom stitch jamming up
seems like the same problem I haad so I tried changing the needle looking for burrs or bent needle. maybe a piece of broken needle in the bobbin holder. or maybe the fabric requires a certain needle or the needle size is too big for the fabric you are using. or the machine needs cleaning I have started using canned air for this. and then if this fails then you should note the tension position and then try adjusting it one point at a time. always puting it back to where it was to start with good luck
Posted on Mar 08, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
louislevel_2
  • 374 Answers
SOURCE: can't pull thread from spool
The sequence of setting up of thread from spool to needle is not complied to actual setting is one factor to be consider it affect the sequence timing of sewing.Particularly some machine are common in starting up threading.fig. shown a basic flow of thread on red color.It maybe a helpful oneb1934dc.jpg
In addition to this the set up of thread to bobbins winder is also need in right place the thread should be in clockwise rotation when coming out to bobbins casing as shown in fig.76e4431.jpg as you can see when thread was pulled out from bobbins winder is moving counter clockwise.If you try to sew, try cotton fabric and set dial to # 3 to 4 and stitch set range to 8 up to 12 depend on layers and thickness,After setting try to sew manually ,turn hand wheel by your hand first,let upper tension catch the lower bobbins tension and arranged thread and insert fabric use hand turning hand wheel several time until stich appear on fabric observed loop thread on lower bobbins on fabric.if accumulation of loop thread on lower adjust upper tension also dial tension gradually until it has a smooth stich appear.
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
  • 240 Answers
SOURCE: I recently received 2 White
Re the bobbins it is the depth that sounts and some of the plastic bobbins are the same as the metal ones(I used to sell sewing machines)so as long as they are same depth when put side by side and same circumferance then another type will be fine. Ive only found 2 different depths in the plastic ones so I dont know which you have. Not sure what has happened with your stitch lentgh. Check the stitch selector is properly on a straight stitch and that the other stitches are correct. A s/mach technician may be able to alter it for you but yo can do no more on that.
Posted on Jun 13, 2009
Why needle is not catching the bobbin thread
All problems like this are caused by incorrect threading of the cotton thread. Even if you have done it before, thread the cotton using the instructions in the manual.
Also make sure the bottom bobbin and its housing are correctly inserted.
Aug 15, 2015 | Singer 3321 Talent Sewing Machine
I have just purchased an LSS-505 machine and I have not been able to get sewing yet. The bobbin thread tangles after about 3 stitches. I have done all the troubleshooting that I know to do, changed n
YOUR BOBBIN IS TOO BIG, when the upper thread passes over
to create the stitch it catches on the rim of the bobbin. Make sure there is no lint caught under it or in it's cradle.
Oct 14, 2014 | Michley Electronics, Inc Lil Sew & Sew...
Is the bobbin case supposed to come out?
Either the case is improperly inserted, or your bobbin case is. Take a look at your user's manual.
Aug 19, 2014 | Singer 4423 Sewing Machine
My brother computerized sewing machine does not catche the bottom thread to make a stitch
try using a longer needle, or lowering the one you have now by loosening the needle screw and dropping the needle down some
Aug 08, 2014 | Brother Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
My machine won't stitch, and the tensions seems to be very high, even after adjusting it.
Hi, if your bobbin has thread, check to make sure the bobbin is inserted into the shuttle correctly. If it is loaded correctly, check to see if the needle is able to pull the thread through the throat plate.
If it doesn't have thread, then all your sewing machine will do is make little holes because the bobbin thread is what catches the sewing needle thread to form the lock stitch to sew the material together . Check your manual on the sewing machine for where it is and how to put thread into it.
Feb 25, 2011 | Juki DDL-8700
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
Sewing machine will not stitch. The thread goes into the material but does not make a stitch. I've changed the needle, cleaned the bobbin, rethread the bobbin and the top thread.??????????????
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
Dec 17, 2010 | Singer Confidence 7467 Mechanical Sewing...
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
Asinger model 5050 will not make stitches,checked all points,
your machine sound like it is out of time you need to take it to a service center
Jan 15, 2009 | Singer 5050 Mechanical Sewing Machine
White Sewing 1415 Mechanical Sewing Machine Logo
394 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
