Question about HP OfficeJet k60 All-In-One InkJet Printer
OfficeJet K60 All In One Problem:Aligning Cartridges
The problem is that the Office jet just keeps on saying:Press enter to align cartridges. I tried aligning them several times now, and each time the paper always appears with a green check for each different pattern that the printer printed. Please help I'm using up all my paper!
  • 4 more comments
  • sino2 Nov 05, 2007
    I have inserted a new HP# 78 color cartridge in my k60 office jet printer
    and the press enter to alige cartridge message keeps coming up.
  • vjpcstjoseph Mar 19, 2008
    My K60 HP Office Jet printer keep repeating the same message over and over "press enter to align cartridges" and it only prints only black and pink test page and or any other document that I send to print. I changed several ink cartridges but still have the same problem. Seeking solutions
  • Anonymous May 13, 2008
    when I get the message align cartridge I ignore it and it works fine
  • Anonymous May 26, 2008
    I am having the same problem after putting in new cartridges.
  • Anonymous Mar 27, 2014
    when i replaced the color cartridge it wouldn't align because it said the paper wasn't on the glass
  • Anonymous Mar 28, 2014
    Not printing Has all new cartridges It has had the pinheads cleaned several times and aligned
  • 24 Answers
In the process of alignment there are two phases:
1. When the message comes to align the ink ..press ok and the page is printed out.
2. Once the page is printed then place the page on the scanner glass and tehn scan the same.
Follow these two steps in the same order and it will never give Align Ink Cart message again.
Posted on Feb 06, 2008
Align cartridges
after align test page have you put on scanner glass and press the scan button to finish the align process. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 05, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Aligning cartridges
take out the cartridges from the printer and then clean the contact points on the back of the cartridges with a clean piece of cloth. then unplug the power cable from the back of the printer and then press and hold down the # and 6 button from the front panel of the printer and then while pressing them down plug back the power cable back into the printer.
then insert the cartridges into the printer one by one and then the printer will start align the cartridges automatically.
Nov 04, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
After installing new ink cartridge. my multi purpose offic jet 6110 keeps saying "failed to align cartridges" though the cartridges seem to be installed properly. any ideas?
HI
try removing all the cartridges and restart the printer ,it will ask to install the cartridges,install them one by one and then see if it prints an alignment sheet,if it doesnt print it this way there is an option to align print cartridges in the printer drivers, goto the control panel--->printers and faxes--->rt click the printer icon and goto properties,under properties there should be an option for either maintenance or service this device button,when you click it ,it gives an option fro aligning the cartrdiges,
Jul 14, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet k60 keeps saying press enter to algin cartridges
Check the controll panel and see if any key is presing down,if not open the control panel and clean the surface with metilated spirit.
Jul 05, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer wont print it keeps saying press enter to alein cartridge
I just noticed in the link to your forum item that additional text appears that does not appear in the item itself. It looks like you are getting a message telling you to press Enter to align your print carriage. This is a common step after you replace an ink cartridge. According to HP.com, here's what you are supposed to do:
"A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete".
The link to those instructions is as follows:
Replace the Print Cartridge
Just follow the instructions I posted above in italics and you should be good to go. Good luck.
Oct 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet K60 Align cartridge problem
ok the link i put here for you is very long page of typing so for hp
i found you the link to go threw the alignment process
sorry i cant type the whole page for you but the link is here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=59273
May 18, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
HP OfficeJet k60 All-In-One InkJet Printer Logo
277 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
