Question about HP LaserJet 2840 Printer
Iam facing in hp 4050 printer,when i have giving command from tray 2,printer is giving error on display 41.3 unexpected paper size but from tray 1 is working ok.i have done already in paper handling menu override latter A4 is yes.
  • 26 Answers
Swap trays and test - if OK then your tray is set up wrong. remove paper and check that it is set for letter. also check the small switch (if there is one) on the Right hand side of the tray that maybe set to customer - change to standard. compare trays so they look the same - and check the settings in the menu for letter / plain on both trays
Posted on Jul 24, 2009
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
41.3 unexpected size in tray 2.my printer is hp laserjet 4200.can you solve this
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet 2420 Printer
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
Hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Mar 11, 2010 | HP Office Equipment & Supplies
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Feb 11, 2010 | HP LaserJet 4050 Printer
I want to print from Tray 2 where I have letter size paper. The printer is telling me to load paper into tray 1 -Error message is 41.3 Unexpected Paper size. I need the printer to select from tray 2 unless...
Assuming the printer is otherwise working ok and we are talking about a Windows operating system....
When you choose the Print command from the drop-down menu in your application, instead of just proceeding, choose "Properties" or "Preferences" in that window. This should open up another dialog window from which you can choose additional printing options. It may be under Advanced or Tray Select, etc.
You can also get to the printer dialog windows by clicking on the Start button, then Settings, then Printers and Faxes, then double-clicking on the printer icon in that window for your printer and proceeding from there.
Jan 02, 2010 | HP LaserJet 4050n Printer
Unable to print on HP officejet 9120. Error ; Load A4 in tray 2, Plain paper. Tray is empty or media type/ size in tray is incorrect. Ensure media in tray matches printer driver or control panel setting.
when you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
Nov 20, 2009 | HP OfficeJet 9120 All-In-One InkJet...
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
HP LaserJet 2840 Printer Logo
569 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
