Question about Canon ImageRunner 1600 Copier
I got canon ir1600 i am receiving an error msg as error 100
    Sergeant:
  • 199 Answers
As sm -
E100
When the scanner motor is started up, the BD input signal does not arrive
within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and
fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal
cycle is not within a specific range (±2%) for an equivalent of 10 mm (print
distance).
cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or
the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause
The wiring is faulty (short circuit, open circuit). The laser scanner unit is
faulty. The DC controller PCB is faulty. The drum unit is not installed.
Remedy
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Posted on Jun 04, 2009
How do I solve a system error E000 on canon iR1600 photocopier?
First you need to clear that error from service mode. If problem persist replace the fixing unit
Jun 15, 2015 | Canon Office Equipment & Supplies
Hoo.comi want to solve the problem in my copier canon ir 2016, error code e354
this is error code that isn't stated in service manual and doesn't have description. When this error occures the procedure is to report to Canon service center. The same errors were on ir1600/2000 series, but without some good explanations.
So, call authorised CANON service partner!
Sep 13, 2011 | Canon iR 2016i Black and White Copier
Want to correct a system error E000 on canon IR1600 photocopier
E000 indicates a low temperature problem in the fuser unit.
  • Check the fuser for any jammed paper and remove it
Check and replace with spare part if needed:
  • the thermo lamp,
  • the thermistor in the fuser unit
A code reset is needed:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 PRINTER, press OK
  3. Go to #4 PRINTER RESET, press OK
  4. YES = (*)
  5. Power cycle the unit.
Jan 05, 2011 | Canon iR1600-2000 PS
Ir1600 copier displayed system error E000, therefore the copier couldn't operate
E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
Nov 13, 2010 | Canon iR1600-2000 PS
Sir,My IR1600 dosnt fuction or now dosenot start to work
Hi, do you have an error message like E100 ? Please be specific.
Mar 22, 2009 | Canon imageRUNNER 1600 Laser Printer
Technical suport
Try checking the fuser section,
1- bad thermistor
2-bad thermofuse
3-bad fuser lamp
Aug 07, 2008 | Office Equipment & Supplies
SYSTEM ERROR E100
Hey
How can I solve this error code(IR1600) on my canon copier by myself?
Nov 27, 2007 | Canon imageRUNNER 2000 Copier
234 people viewed this question
old marine
old marine
