Question about Human Touch HT 7450 Massage Chair
After a few minutes, all 3 lights to the left of
After a few minutes of use, all 3 lights to the left of the width button flash simultaneously & then the chair shuts down.
  • NipNapTappy Dec 31, 2010
    Did you solve this problem John? I have the exact same problem.
This is a problem with the width/kneading cam motor or the portion of the PCB that controls this motor. None are available as separate replacement parts. Human Touch will only sell the entire backrest assembly which costs about $600 plus another $60 for shipping. It can be replaced without tools in less than five minutes.
Posted on Mar 23, 2014
3 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Posted on May 29, 2009
bronk50
  • 27725 Answers
SOURCE: I left the amp in on in Normal mode (not Tube
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Sep 16, 2010
I bought sj-5501 Sharp fridge . Yesterday I have no lighting on the front panel display of the refrigerator The refrigerator works right What could be the reason ? Thanks,
You can try one of these;
1. Hold down "Energy Saving" and "Lighting" buttons simultaneously for 10 seconds (or top left & right buttons). Display panel returns immediately
2. press the Freezer and Ref buttons at the same time for 8 secs and Bam!!!! Bac 2 normal!
3. pressed the power freeze and vacation buttons for about 3 secs and it worked
4. I held the top left and top right soft touch buttons on the screen itself (which I think is the power save and the lighting buttons) and held for about 8 - 10 secs and it reset
Hope it helps. Its in the combination of two buttons pressed simultaneously. Try your luck.
May 16, 2016 | Refrigerators
Set time on adidas Adults' Performance Duramo Watch
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Mar 15, 2012 | Adidas Watches
How do i program a black & decker model cm1050w to start coffee breding at a certain time?
I have one. It's easy. Push the program button. The little green light in the lower left corner will flash. The only tricky part is that you only have about 3 seconds to begin setting your time. After that the light stops flashing and you will be changing the regular time. While you are pushing the Hour or Minute buttons you have all the time you need to set your brew time, but once you stop you're back to the 3 second timer. Remember, if the light in the upper left side is on, the time is PM. To turn the timer on, push the Auto button and the little light in the lower left will come on and stay on. To turn it off, just push the Auto button again. Another caution, there is no "safety" for the Hour and Minute buttons. If you push either of those buttons while the lower left light is flashing you are changing the brew start time. If it is not flashing you are changing the real time. In other words, if you push either of those buttons at any time, you are always changing something. Happy brewing.
Sep 12, 2011 | Health & Beauty
My Kodak ESP-3 printer is not printing. There is a red light flashing and I do not know what it means. it is under the on off button. It just shoots out blank paper Kathleen
Clean the printhead, then print a test page.
  1. On the control panel, press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes. The On/Off light continues to flash during the cleaning procedure.
  2. When the On/Off light glows steady, press and hold Quantity + Cancel simultaneously until the On/Off light flashes, then wait for the test page to print.
  3. Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  4. Is it still printing blank?
  5. Please :Call Kodak to Report Code BP03
United States Telephone Support spacer.gif spacer.gif All-in-One Printer Phone Support
Live phone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight Eastern time, 7 days a week.
The expected wait time for phone support is 15 minutes
  1. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
Dec 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I program my clock on my 2001 Yamaha Roadstar 1600?
View the service manual at this URL : http://www.scribd.com/doc/17625151/servicemanual1602082008 : and scroll down to printed page 3-62 or electronic page 120.
Copying from that page:
1. Turn the main [ignition] switch to "ON".
2. Press both left and right buttons simultaneously [i.e., the 2 buttons below the speedometer glass] until both hours and minutes flash
3. Push the left [mode] button and the hour display will flash
4. Push the right [right] button to change the hours.
5. Push the left button and the minute display will flash.
6. Push the right button to change the minutes.
7. Push the left button and both hours and minutes will flash.
8. Push the right button for two seconds to set the clock.
Sep 01, 2010 | 2002 Yamaha Road Star
AC unit goes on and off every 3 minutes
It should not be doing that. The thermostat is pre-programed for only 4 cooling cycles per hour. You can change the program by :
�� To access the configuration menu, press both up/down buttons
simultaneously for 3 seconds.
�� To go to the next parameter (menu item), briefly press both
buttons simultaneously.
�� To modify a parameter, press one of the buttons.
�� Repeat steps 2 and 3 if necessary.
�� Press both buttons simultaneously for 3 seconds to exit
the configuration menu.
You are looking fpr parameter CPH this number tells the unit how many time per hour to come on lower it to leghten the time betwen cycles.
Jul 12, 2010 | Honeywell Electronic Programmable...
Nortel M7324 CAP stops working after changing UPS
The buttons will all have to be reprogrammed. Try this:
Press "Feature * 2", then press the button to be programmed, and enter an extension number. You will have to do this for each button.
Alternatively, you can unplug the phone for 1 minute, and plug it back in. The lights will start to flash on the phone, and stay solid on the KLM. When the lights begin to flash on the KLM, simultaneously press the bottom 2 buttons on the left-side and the bottom 2 buttons on the right-side of the KLM. This will cause each button to light momentarily from the top-left to the bottom-right, and will program the buttons, in ascending order, automatically from the first extension in the system until it uses all available buttons on the KLM.
Hope this helps!
Nov 25, 2009 | NorStar M7324 Telephone
Blinking panel button lights
That has to do with your computer for your body controls, such a/c, heater, wipers, etc...
Most common problem is drinks spilling into the computer which is right between the cup holder. It will eventually cause a problem with a/c most likely.
Jun 24, 2009 | 1998 Dodge Caravan
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
Program garage door opener
You must first erase what's in the memory.
1.) Simultaneously press both buttons 1 and 3 on the Audi's built-in remote. Hold them until the indicator light flashes (20 seconds or longer).
2.) Now hold your garage door remote close to the Audi remote.
3.) Simultaneously press and hold both your garage door remote button and the button you would like programmed. The indicator light will first flash slowly then rapidly.
4.) You may release both buttons once the light flashes rapidly.
Jul 01, 2008 | 2000 Audi A6
Human Touch HT 7450 Massage Chair  Logo
260 people viewed this question
Top Human Touch Health & Beauty Experts
Michael Vincent Cruz
noel
noel
Barrissimo
Level 1 Expert
Are you a Human Touch Health and Beauty Expert? Answer questions, earn points and help others
