My disposal was jammed a few days ago, and while it was jammed (before I realized it was jammed) I ran the dishwasher (a Bosch). needless to say, that was pretty nasty in the sink, but the washer ran through its cycle fine, although there was a little water on the botom. I figured my roommate had opened the washer before it finished or that because the sink had sort of backed up, there was residule in the washer. I have since fixed the disposal. Now, I ran the dishwashewr last night, and I though it had gone all through its cycle, including drying and the annoting beeps at 1 in the morning when it finished. However, upon opening, I realized it never ran any water, though there was now NO WATER in the bottom. Now, whenever I turn it on, it sounds like it is running the drain, though there is no water, and nothing else happens. HELP!
My Bosch Integra SHU 9956UC is not cleaning properly after 8 years of use. Checked spray arms for...
(More)
My Bosch Integra SHU 9956UC is not cleaning properly after 8 years of use. Checked spray arms for spin and clean, no drainage issues, top rack worse than bottom rack in terms of dirtiness, blew compressed air back into machine to clear lines.
The dishwasher runs but the top sprayer bar does not move. Water comes out but it stays in the same...
(More)
The dishwasher runs but the top sprayer bar does not move. Water comes out but it stays in the same position. the top level 'stuff' is not clean. i have even tried running it empty - same problem.
My 5 year old dishwasher won't stop running. It doesn't go to the next cycle and pump out the soapy...
(More)
My 5 year old dishwasher won't stop running. It doesn't go to the next cycle and pump out the soapy water. When I turn it off and try to start over(when it will ordinarily start pumping at the start of a new cycle, it just wants to continue running. Is it some sort of timer or circut board gone bad?
6-7 yr old Bosch Integra Ltd dishwasher. Handle screws came loose. Unscrewed "star" type...
(More)
6-7 yr old Bosch Integra Ltd dishwasher. Handle screws came loose. Unscrewed "star" type screws to remove interior door panel and gain access to reattach handle. However, I can't figure out how to remove the interior panel. Thanks. Jon
