Question about Kyocera RI-3530 Black and White Copier
Light copies recently done a 100 k service. now getting light copies. have replaced the k charge again, but still lght
    New Friend:
  • 120 Answers
Did you calibrate the new developer correctly.
Posted on Jan 26, 2008
Clean the mirror and the lens and the laser unit inside
Posted on Dec 13, 2007
  • 33 Answers
Toner sensor not set properly, or the toner sensor is bad. what is the make and model, it would help to solve your problem faster.
Posted on Oct 28, 2007
SOURCE:
Konica minolta bizhub 601 warming up option donot show ready to copy
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 19, 2018 | Konica Minolta Office Equipment & Supplies
When want a copy ,it says ready to copy but won't. ?
Sir/Mam,
Apr 30, 2016 | Konica Minolta Bizhub C350 Digital Copier,...
My machine don'y copy, I receive message:Now warning up. Ready to scan
Sir/Mam,
Feb 26, 2016 | Konica Minolta bizhub 750
How much do a repair shop charge to replace a Engine Coil cause every time my 2000 ford Expediton (Service eng. Lght.) comes on its the engine coil went out. My oil is fine.
You phone around and get some quotes in the region where you are located. But don't assume the problem will be a coil every time you get a check engine light. Have the vehicle properly scanned to see what fault codes the computer s generating and take it from there.
Oct 27, 2015 | Ford Cars & Trucks
Alternator lght comes on when starting the car and after running a few min the alternator light shus off
The alternator is failing and not charging fully! Probably the carbon brushes are worn or sticking, if sticking just need cleaning up and if worn replace the alternator! Depends on how many miles the alternator has done!
Jan 04, 2015 | 2004 Pontiac Grand Am
HP DV2500 Battery charged to 100% but dies within minutes
Your battery is done. Batteries only have a useful life, and after that you have to replace them because they will not recharge or hold a charge.
May 30, 2012 | Office Equipment & Supplies
My bizhub 600 is showing message warming up ready for next copy
Sir/Mam,
Mar 31, 2012 | Konica Minolta Bizhub 600 750 Image...
My phone will not charge? when i put the charger in sometimes the red lght comes on and sometimes it doesnt. Either way it will not charge at all.
hi friend,
this problem happens to more phones when another sutable charger is tried to insert in the charging slot of ur mobile phone......
get it to a costomer care and change the charging slot
Jul 12, 2010 | Sony Ericsson K610i Cellular Phone
New pc.. old router. not detecting internet
YOUR ROUTER IS NOT COMPATIBLE WITH VISTA NO WORK AROUND OR FIRMWARE UPDATE WILL WORK.REPLACE.RICHARDM69
Dec 08, 2008 | Microsoft Broadband Networking MN-100...
Kyocera RI-3530 Black and White Copier Logo
56 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
gggg
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
