Question about ASUS P4P800-MX P4(S478) Prescott/865GV/FSB800/SATA/A&V&L/MATX Motherboard (MOTAS81)
Looking for usb connections on the p4p800mx motherboard
    Novelist:
    Champion:
  • 256 Answers
All USB socktes are embeded in the MBs, they used to have only plain USB's, but since the USB and the USB 2.0 are not always compatible, they give you 2-4 sockts USB 2.0 under where the mouse and keyboard sockets are. The straight USB are placed much lower, above the inputs and outputs, either parallel to them, or in a vertical raw. If you need more information, we will happy to assist you, but we will need the computer name, the model number, and the MB ID, which usualy is located in between the white PCI socketsor around the RAM memeories at the upper right corner of the Mother board. Thank you for considering our service; we are sure that we can help you...
My name is Constantin (arzconst is my nickname for Fixya.com)
Posted on Jun 05, 2009
No video or boot. Nspire with P4P-800MX
Hello try to download the manual here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800MX/#download
Please select your windows system.
Next open the manual folder, and click on global for download.
You will need adobe reader, to read the content.
The problem could be the power supply failing, or bad capasitors on the mainboard:
If the problem did not occur before the power outrage, i suspect the power supply failing.
If you change the power supply, take antistatic precautions when working on the mainboard.
Good luck
Jan 06, 2013 | ASUS P4P800-MX Motherboard
J ai beaucoup de probleme avec mon desktop p4p800-mx chassis intruded
You have a problem with the Chassis Intrusion part, of the Asus P4P800-MX motherboard?
The Chassis Intrusion header is below the CMOS battery to the left.
It is in-between the two black SATA connectors.
It is a 4-pin header.
From -> LEFT to RIGHT pins are numbered 1, 2, 3, and 4.
Put a Jumper Cap on Pins 3 and 4, and bypass the Chassis Intrusion option.
In the -> OS box, click on the blue Down Arrow. Now click on Windows XP.
In the drop down list, click on the + sign to the left of Manual (5)
Version E1880 - P4P800-MX user's manual (English version) E1880
Click on the blue -> Global
Go to Page 35. (PDF file page. Manual page is 1-25)
Chassis intrusion connector (4-1 pin Chassis1)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 06, 2012 | ASUS P4P800-MX Motherboard
I need a drivers for sound and intergrated graphic card on Asus p4p800 mx motherboard. I can not find it anywhere. Can you help me? Thanks
Hello the driver can be downloaded here:
Select the operating system and the driver you want
The driver must be unziped before you can install it.
Good luck
Sep 19, 2010 | ASUS P4P800-MX Motherboard
I had to change the motherboard as it failed
Look at the front panel of the computer you will see the connections you have. Should be power, reset, power led, usb etc. These are connected to your current motherboard and most times all the connections will be labeled in the case, on the wire connector ends. IE the end that connects to the motherboard. The only exception to this is the usb ports, and they can be hooked up to new usb connectors on the motherboard. Also note, read i said READ the proper way to connect the usb to the motherboard, this is usually a one shot deal, get it wrong and you kill that usb connector.
Apr 24, 2010 | HP Media Center M370N (DM163A#ABA) PC...
USB wiring on KT4AV MS-6712 Ver 10A motherboard
Open the link provided; http://www.directron.com/installusb.html
You will need to scroll down until you see, Intel Standard USB header Layout. Also see: Common USB case header connectors.
Hope this is what you're looking for.
Cheers'
Mike
Feb 07, 2010 | Intel Motherboard
Front usb motherboard ports don't work rear ok. os/windows 7
You've probably connected the pins wrong. You should find the manual and see how your front USB ports must be connected
Feb 05, 2010 | MSI PM8M-V Motherboard
I want to connect the extra usb from the ATX but i have 8 wires and on the motherboard 13 connectors
monkybrain
In regards to connecting the USB wires this is common because not all case/USB connectors use the same pin connection. What you will need to do is look up the info in your motherboard manual to see where the pins go. Note the wires/connectors should be labeled as well.
Hope this helps
Issken
Jan 10, 2010 | DFI AD70-SR Motherboard
How to connect the usb front panel
There are connectors on the motherboard for the usb connectors that go to the front panel. Look at you manual and connect the connectors correctly. Each connector has 4 wires, with a red(+5volts) and black on each end. Make sure plug these in correctly on the motherboard connectors since a backward connection will burn up your usb device when it's plugged into the usb port. Been there done that! It should say something like this in the manual, VCC, USB1-, USB1+, GND.
Sep 25, 2009 | MSI MS-6547 Motherboard
How do i connect my extrernal usb ports
Just look at your motherboard you will see soket with 9 pin with written word USB1 or 2 so connect that soket with your external usb cable. it will work
Aug 17, 2009 | MSI 865GVM2-LS Motherboard
Usb cable
If you are talking about something like a front usb socket that's connected inside the PC then look at this picture as an example.
http://i48.photobucket.com/albums/f217/StuartB4/9-PinCardReader.jpg
Just look on the motherboard for these connectors.
They are usually marked usb on the board.
Mar 22, 2008 | Intel Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
