Question about Sony NW-E405 MP3 Player
Format error it display format error and its read oooo kb\s and its show the amout of minute ought to play
When you get the format error there is a couple of things you can do first try this if it has been reformatted and there isn’t any files on it get the sonic stage installer online somewhere not sure where run that and follow its prompts and when this is finished it should put the correct software onto the player which you can open to see if it is there. Then disconnect the player from your computer and hold down the search button for about half a second when the player is in stop mode rotate the switch at the top of the player till you get “advanced menu” and then press the play button to select it and rotate the switch again till you have “format” and press the play button to select formatting will blink and start formatting when finished complete comes up press the search button to get out of it and back to the main menu and hopefully it will work now!!! It worked for me anyways and couldn’t find a simple answer online so I said id throw this up there!!! Hope it works for yee too!!!
Posted on Oct 31, 2007
THANKS A LOOOOOOOOTTTTTTTT!!!!!!!!!!!!!! I spent half of my life looking for the solution :) seroisuly. .. great work... thanks again..!!
Posted on Nov 25, 2007
Crashed error 03-FFFF-OOOO
if that error occurs while attempting the recovery, typically it indicates a read write error on the hard drive. replace the hard drive and see if the recovery finishes.
(although i have only seen this problem with failing hard drives)
Nov 03, 2009 | Sony Toshiba Qosmio F45-AV411 Notebook
I have a scandisk pen drive it show free space 0 kb and use space 0 kb and shows disk unusable plz help
Format the drive by right clicking on its icon and selecting format. Once in the format window, click start. This will take a few minutes and will check the disk for errors as well as format. If you encounter errors while formatting, it may be that the device is defective. Otherwise you should end up with a functioning pen drive.
Nov 02, 2009 | SanDisk Computers & Internet
Snoy NW-E105
I had the same problem and struggled with it for some time. I forgot the format feature on the device itself and kept formatting from my pc. This won't work.
The solution:
1. Unhook your device from the pc by pulling out the USB cable.
2. Click the "Menu" button 1 time (found on the back of your NW-E105 player).
- This will show "Display"
3. Click the " |<< " button 3 times (the button to rewind track).
- This will show "Format"
4. Click the Play/Stop button 1 time.
- This will show "Format: N"
5. Click the " |<< " button again 1 time.
- This will show "Format: Y>
6. Click the Play/Stop button 1 time (wait for "really?" prompt), click it again.
Now your device is formatted and will play the files you add to it.
Oct 07, 2008 | Sony Network Walkman NW-E105
How too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Sep 15, 2008 | NorStar T7316E Corded Phone
How to change the time on screen
generic for all phones... the standard way to change the time and show it on screen is simply going to the settings and look for time settings... in here, you can actually change the time, the date , and the year and you can also change the time format form 12 hour to 24 hour.
Apr 08, 2008 | Lands Phones
Format error
what type of mp4 player is it, and what type of files are you trying to upload?
Jan 28, 2008 | Apple iPod MA446LL/A MP3 Player
Snoy NW-E105
ok go to my computer right click format then use itunes which will reinstole settings or one from snoy?
Jan 03, 2008 | Sony Network Walkman NW-E005 MP3 Player
Sandisk microsd 2 gig won't read
maybe you ought to format it ? .. also try changing the file system when u format it
Oct 29, 2007 | Electronics - Others
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
Jun 21, 2007 | Canon PowerShot A80 Digital Camera
"Format Error" after format with windows explorer (XP)
Hello, please check this link: If you need more info please advice. Arpi
Feb 01, 2007 | Sony NW-E405 MP3 Player
Sony NW-E405 MP3 Player Logo
74 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
