Question about Spark Plugs BR4HS Plug 10/BX #3322
1996 grand am
How do I get the rear spark plugs out easy?
  • 132 Answers
There is not a real easy way it take your spark plug socket and your ratchit you might need an extention if there isnt enough room for a ratchit use a wrench thats why the spark plug sockit looks like a bolt on the back.
Posted on Jun 04, 2009
96ply grand voyager enine turns over but wont start,had battery charged,now lights flashing in dash,ac,rear wiper,4lights total,cam sensor wires old breaking off at connecter,
You 1st need to determine if you have a fuel problem or an electrical problem. 1st pull one of your spark plug wires and find an old plug to stick inside the wire. If you don't have one, remove the plug from the engine and use it. 2nd, with the plug inside the wire, place it someplace on the metal portion of the engine so that it is grounded. Then as you spin the engine over, have someone watch the end of the plug to see if there is a spark or not. If there is, then more than likely you have a fuel problem. If no spark, you have an electrical problem. Check that and them repost your message.
Nov 05, 2014 | 1996 Plymouth Grand Voyager
Replace spark plugs
If you have the 3.0 liter you can rep,ce the air cleaner housing from the back side of the engine and get to the rear spark plugs. The other two v-6 options the rear plugs need to be done from underneath the vehicle.
Aug 07, 2012 | 1989 Dodge Grand Caravan
Whats the best and easiest way to change the 3 rear spark plugs on a 1996 pontiac grand am 3100
If this is the same question about the dog bone, its been answered.
Sometimes you can reach the plugs from under the car too.
Jul 27, 2012 | 1996 Pontiac Grand Prix
Show engine spark plug cylinders on 2000 mercury grand marquis 4.6l
Firing order 1-3-7-2-6-5-4-8 Cylinder locations: Passenger side starting at front of engine and going to the rear: 1-2-3-4 Driver side front to rear: 5-6-7-8 This actually for a 1996 model, but I should imagine it is the same.
May 20, 2012 | 2003 Mercury Grand Marquis
How do i chance plugs and wires in my 96 grand voyager , Im thinking i mite be abel to reach from under neath but looks kind of tight ??
Is this the rear bank that you are having trouble with.....I do not know about the 3.0l but the 3.3l is greatly eased by removing the upper intake manifold. Disconnect the throttle body and rear alternator mount bolt then remove the bolts holding the upper intake to the lower intake. Now all 3 rear plugs are in easy reach. Reassemble in reverse remembering to torque appropriately.
Sep 20, 2010 | 1996 Plymouth Grand Voyager
How to change the rear spark plugs of a 96 plymouth voyager
The engine plenum will have to be removed. This is what the air goes thru to get to the engine intake. Remove ground, mark tag remove required cable, wires and hoses, take digital photos as you go. Be patient. The good news is we don't have to change them every 20K miles.
Tom
Jun 08, 2010 | 1996 Plymouth Grand Voyager
Oil by the spark plugs
the valve cover gasket has inner gasket some times called spark plug tube seal. so replace valve cover gasket will fix it
Feb 26, 2010 | 1996 Pontiac Grand Am
How to change back spark plug on 3.1
I used to have a Pontiac in which I had to pull the front tire off and then get to the plugs by going over the A frame. Doesn't mean it will work on your Grand Prix but you might try it.
May 29, 2009 | 1996 Pontiac Grand Prix
Spark plug diagram
the spark plug at the front of the engine (nearest the grill) is #1 on both the 4cylinder and 4.0 in line six cylinder.
Aug 07, 2008 | 1996 Jeep Grand Cherokee
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
49 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
