Question about Motorola Mobility RAZR V3
How do i setup voice dialing to my bluetooth with my razor i have looked and looked
  • 20 Answers
Settings>Headset>Voice Dial It isn't actually in the Bluetooth Settings. Hope this Helps =)
Posted on Jun 04, 2009
How to use voice dialer (svoice) with bluetooth on galaxy s5
Corded headsets do not have Bluetooth. Do you have a Bluetooth headset (wireless) handy to test the Bluetooth function properly?
Nov 04, 2014 | Samsung Galaxy S5
Lost manual . How do I get it to ask me who I want to call?
Voice dialing with the Explorer 220:
With the headset on, press the call control (answer) button for around 2 seconds to activate the voice dialing. This should prompt your phone and you should typically hear "say a command", then you can say, for instance, "call home". It will then confirm the command by saying "did you say call home?" And when you answer "yes", it should start dialing.
However, just remember that to use voice-activated dialing, your phone and cellular service must be capable of voice-dialing and this feature must be enabled on your phone. See your Bluetooth phone manual for instructions. Also, here is a link below for the Explorer 200 series user guide.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Aug 15, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to operate a bluetooth
Most modern bluetooth's rely on your phones built in voice dialing (if your phone has it) which is relayed through the device. Familiarize yourself with how your cellphone handles voice dialing, once this is done there should be a multi function button on the unit that you press to activate voice dialing. It could also be by voice if it is voice controlled.
Regards,
Rylan
Dec 15, 2010 | Plantronics Explorer 230 Bluetooth Headset
Blackberry 8530 cannot find / pair with bluetooth Samsung stereo headset. Tried putting both into discoverable mode, no help. This headset will pair with my Blackberry 8320 phone, but the music speeds...
1. Turn on Bluetooth headset and Blackberry hand-held.
2. Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
3. Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window
4. Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list
5. Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
Use your Bluetooth Headset with your Blackberry
1. Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset 2. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
3. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Dec 03, 2010 | Insignia Bluetooth Wireless Headphones...
I want to make and receive handsfree calls using an LG HBM-730 bluetooth device and an LG CF360 phone. I have the bluetooth and the phone connected and can receive calls and make calls. The kicker is...
Hello.
From LG Documentation:
To make a handsfree call from the bluetooth device (Voice dialing)
- Briefly press the PWR/END button to activate “Voice Command”.
You will get the best results if you first record the voice dialing tag through
your Headset.
Hope this helps
Mar 09, 2010 | Cell Phones
HF850 pairs with my Ericsson TM506 phone, but can't voice dial
The TM506 (also known as Bella) must support the Bluetooth Handsfree 0.96 profiling.
The HF850 supports Bluetooth Headshet v1.1, v1.2 and Handsfree 0.96 protocol.
Unless you can find otherwise, the TM506 doesn't support Bluetooth 0.96 Profiles. It is my understanding that on the TM506 you must program your voice commands and I understand that to be different.
Nonetheless, the TM506 works very well and seamlessly (other than voice dialing) with the HF850.
Dec 24, 2008 | Motorola Mobility Bluetooth??¢ HF850 Car...
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
Unable to find Voice dial for bluetooth carkit
in your settings you have car setting try there first
Jan 04, 2008 | LG Prada KE850 Cellular Phone
RAZOR V3 VOICE DIALING
If you have the v3xx, it has speech recognition built in, you just press the voice dial key on the right side of the phone and say "name dial", then say the name of the address book entry you want to dial. The speech recognition matches up with your address book entries and repeats the name back to you. If you have multiple entries, it asks "which one". It's very cool and mine works very well. I was going through the same frustration you mention, looking for a way to add a "voice tag" to an address book entry like my old phone, but this is way cooler! Hope this is the fix for yours as well, good luck!
Dec 14, 2007 | Cell Phones
Voice dialing
Shelly, I use a nokia N90 and you are right that one can not call by voice dialing. What I did was put the phone numbers that I frequently call in speed dial. Whe I want to call somebody I just press the speed dial number.
Oct 05, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility RAZR V3 Logo
186 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
