I have an ibm mother board and i dont know what type of ram it needs it has a 2.8 procesor and it has 4 black slots for ram
    Habit-Forming:
  • 53 Answers
On the processor itself, you should see a marking to say what kind it is (AMD K8 X2 4800, Intel Pentium 4, etc) and a longer number. Many times, when you enter that number into google, it will tell you what type of processor it is, what the system bus is and the type of ram supported. EX: system bus 400 MHz means that it will most likely use DDR RAM. System bus of 800 will mean DDR2 RAM and so on.
Posted on Jun 04, 2009
  • 10,515 Answers
It will be in the manual; if you have lost it, and know the model of the laptop, the the company's website would have the type of memory:
These two sites could help you:
http://www.computermemoryupgrade.net/adding-more-memory.html
http://www.notebookreview.com/default.asp?newsID=2612
Thanks.
Hey, the computer starts with no beep or continuous beep. thanks
May be the RAM Problem
For solving the problem do the following:
1. Remove the RAM(s) from its positions / place from the mother board
2. Clean the RAM slots inside the mother board with a neat and dry brush
3. Rub the "RAM (Copper Bottom) with an eraser or with hands gently for a few seconds.
4. Place the RAM in their slots and restart the system
Let me know! that i Fixya the problem
Thanking you.
B.Krishnamacharyulu
Nov 08, 2010 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
No power ON of mother board
Get a power supply tester $10 ebay and test the PSU. led lights show if it is ok. often the PSU will run and appear to be ok. But will have below voltage when load comes on.
Apr 01, 2010 | Intel D845GVSR Motherboard
My PC don't start,the power give a corect values to voltage
just take the ram out and put it back. sometime when the ram hangs which wont let the pc start. and another solution for it try disconnect the power supplly plugs and reconnect them to motherboard. and switch it on hopefully it will start.
Mar 30, 2009 | Computers & Internet
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Toshiba A200 1Ai memory slot not working
new board, the actual ram slot is toast, you can get a replacement board from Toshiba themselves but at a retarded price, at this point cheapest thing to do would be to just put in one 2 gig stick in the working slot so at least you have 2 gigs and forget about the other one (replacement mother-board for your machine is roughly 200 bucks) i checked it at work (future-shop)
Dec 24, 2008 | IBM ThinkPad R32 2658 Notebook
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Ram install problem
with RAM there can be a few problems
1) the frequency of ram which *********** board supports might be less than the freq at which the ram you are puttin works, hence in this case RAM wont work on this mother board and ull have to get the RAM replaced
2) some motherboards do not support a 2 x 1 GB RAM where as they might support a 1 X 2 RAM (if you do have 2 mem slots for ram)
and then there is the most trivial problem of the slot not being clean or arm not being put properly, i can think of ne other reason for the ram not working properly..
cheers
Kushal
Aug 21, 2008 | IBM NetVista PC Desktop
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Mother Board and And Ram
You dont say how much ram you have currently, so go to this site to inform of the type of ram you need. http://www.crucial.com/
Sep 20, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
