Question about Welding Tools
WONT WORK,NEED WIRE DIAGRAM .ASAP .PLEASE.......HELP......
Have got a AC/DC MITEC TIG WELDER THATS ABOUT 12 MONTH OLD,AND FAILS TO WELD,ONLY SMALL SPARKS FROM THE HAND PIECE,HAVE TRYED TO GET IT REPAIRED WITH NO ONE HAVING ACCESS TO A WIRE DIAGRAM,CAN ANYONE PLEASE HELP?????
  • Larry
    Larry May 11, 2010
    Yes I may be able to help you BUT need the exact model number please.
  • Thomas May 11, 2010
    What model?
  • 2712 Answers
SOURCE: TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Posted on Aug 27, 2008
CarlGehrke
  • 169 Answers
SOURCE: miller syncrowave 200 makes buzzing noise from spark gaps.
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
Posted on Jan 26, 2009
  • 3 Answers
SOURCE: TIG 250/250
have you checked your regulator if its gone you wont get gas
Posted on Jun 02, 2009
GiantTechGuy
  • 25 Answers
SOURCE: my giant wse 200 tig inverter single phase AC/DC
Hi, remove the machines cover with the machine unplugged then look for disconencted plugs etc within the machine. careful where you place your bare hands.
Posted on Oct 18, 2009
GiantTechGuy
  • 25 Answers
SOURCE: MITEC SUPER 200P AC/DC TIG WELDER,, FAULTY ,,
Common problem with the SUPER series of Chinese machines. If you can provide some photos of the internals I might be able to help you.
Posted on Nov 09, 2009
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
I have a mishto 220 mig tig mma I can get the arc to work fine but the mig there's no arc at all the machine sounds like its welding but no arc at the gun I'm using gassless wire I thought it may be an...
They told me at welding school the mig transformer has a different slope (whatever that means?) to the tig and mma transformer so I am a little surprised at your question. The implication is two transformer are needed for the three types of welding and for tig and mig a dc converter and also for dc mma welding.
From your description it seems as though welding current is not arriving at the tip of the mig torch or the current is arriving in the wrong form.
You say the mma is fine but you didn't say whether it is fine on ac welding, dc welding or both. I have not tried mig welding with ac and have no idea whether it would be successful but I imagine a lot of sparks and not much welding. The problem could be the rectifier unit is either not working or is switched out of the circuit.
Polarity is important too with dc tig and mig welding.
I hope this provides food for thought.
Feb 04, 2015 | Welding Tools
How to set up welder or aluminum tig welding
If you want to weld aluminium with a welder, your machine must be an AC/DC welder, then you will use only AC to do the weld, but as well you must have a contineous high frequency and according to what thickness you want to weld a water cooling argon torch wont be a luxury
Aug 25, 2014 | Welding Tools
Aluminium welding settings
Check your manual or the welding rods data sheet. The settings depend on what you will weld. Consult online manuals and welding charts. These will help you a lot.
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
GIANT WSE 200 amp ac dc tig welder
Buy a new circuit board as it will be cheaper in the long run as the solder has damaged vital parts on the board. It will take a lot of frustration in fixing all parts .
Apr 04, 2013 | Welding Tools
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
How too set up a tig welder for welding thin steel?
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
Dec 01, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
My giant wse 200 tig inverter single phase AC/DC welder wont power up when plugged in have anyone got a wiring diagram.
Sep 26, 2009 | Hobart Welders Champion 500433A Factory...
Welding Tools Logo
116 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
