Mp3 usb player is detected as a USB 2.0 Bootloader device, i can't access to it.please help me solve this
bogus
SOURCE: WINDOWS MEDIA PLAYER WONT DETECT DEVICE
i had a similar problem (would not load driver) and was able to solve with the following: 1. install version 10 or greater of windows media player. 2. in Device Manager (hardware tab on System in Control Panel) right click the ? Samsung YP-T7J and pick update driver 3. Select No, not this time, Next> 4. Install from a list...., Next> 5. Don't search, I will choose.., Next> 6. Select Portable Devices, Next> 7. Select MTP Device, Next> 8. The drivers are copied and the device is recognized. There are other prompts depending on your media player config, but only pertains to how the device is handled. jlw.
Posted on Mar 20, 2007
SOURCE: s1 mp3 player
first u have to download driver of that device then it will be detected and u have to extract firmware from same device of ur friends with same capacity and upgrade that file in ur player
Posted on Oct 26, 2007
  • 5 Answers
SOURCE: bootloader usb init
basicly the software is corrept.take it 2 a cell 4ne repair shop they will fix it it cost about 150.u cnt do it on ur own coz it takes a specail soft ware n only certain ppl have it
Posted on Jul 28, 2008
SOURCE: Snoy NW-E105
I had the same problem and struggled with it for some time. I forgot the format feature on the device itself and kept formatting from my pc. This won't work.
The solution:
1. Unhook your device from the pc by pulling out the USB cable.
2. Click the "Menu" button 1 time (found on the back of your NW-E105 player).
- This will show "Display"
3. Click the " |<< " button 3 times (the button to rewind track).
- This will show "Format"
4. Click the Play/Stop button 1 time.
- This will show "Format: N"
5. Click the " |<< " button again 1 time.
- This will show "Format: Y>
6. Click the Play/Stop button 1 time (wait for "really?" prompt), click it again.
Now your device is formatted and will play the files you add to it.
Posted on Oct 22, 2008
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
I have my mp3 player plugged into the computer and when I go on Itunes it does not show up.
Is this on a Windows computer?
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your MP3 player.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | Computers & Internet
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
My MP3 player turned into a bootloader USB device.
check ur usb cable.in spite of this problem u can try from ur mp3 and format it. but if not then hardware problem
Jul 23, 2009 | Audio Players & Recorders
Usb pen drive not detected
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jul 11, 2009 | Pen Drive IVO MP3 Player
My sandisk sansa device does not start in my computer
Here are a few things you can check:
1. Try different USB ports 2. Check the USB mode on device (Menu --> Settings --> USB mode: Auto Detect/MTP/ MSC) Try interchanging them. 3. Try restarting your PC 4. Try powercycling your mp3 player.
Jan 23, 2009 | SanDisk Sansa m240 MP3 Player
Computer Won't Let Me Access the Device
hey there!
please do the following one by one
unplug the power cable going into the power supply. wait for a while and plug it back
install software with updated drivers. check to make sure you have the most recent motherboard drivers.download if necessary.plenty of sites available
update your windows media player
get Windows XP Service Pack 1 or Service Pack 2 if possible
goto Start Menu->Control Panel->System and then clicking the Hardware tab and going to Device Manager. in Device Manager you could delete all entries with "USB" in the name and reboot. let Windows redetect the USB devices.
uninstall your usb drivers and download the latest ones available and reinstall your usb drivers.
Dec 05, 2008 | Apple iPod nano
Sansa mp3 player not detected by system
1. I assume you are using a USB Port to connect the device?
--Yes - Continue - If No, please specify connection method
2. Does using another USB Port on the PC make any difference?
--No - Continue - If Yes, that port on the PC is not functioning.
3. Are other USB devices that you plug into the PC detected?
--Yes - Continue - If No - the USB system on the PC is not functioning - upgrading or reinstalling the driver might work if it is not a hardware malfunction.
4. Did you install any type of driver for the Sandisk mp3 player?
--No- Continue - If Yes - uninstall and reinstall the driver.
5. Do you have another USB cable to try with the device?
-- If No, try another PC.
CL23
Feb 15, 2008 | Computers & Internet
My sony VGN N220E does not detect external devices
Try reinstalling your usb ports.
1. goto desktop, right click on my computer and press manage.
2. goto the device manager, find the usb devices / ports.
3. Make sure you are useing a ps2 mouse / keyboard since if your mouse/keyboard is connected to usb they will stop working untill your pc is restarted and the devices are reinstalled.
4. Uninstall all usb devices.
5. after all usb devices are uninstalled reboot the pc.
If the problem is with your drivers ( your pc detects the mp3 player but no drivers found) Download the newest drivers for your product and operateing system from the vendors website.
Nov 30, 2007 | Computers & Internet
My samsung MP3 player is not detected
You see, thats the kinda the same way for me. it like works only on win. xp. maybe the usb thing is dirty. try blowing in it. im sorry if this isnt that helpful. try takin it apart to. its hard but easy at the same time. AaronJ.
Jun 13, 2007 | Samsung YP-U2X Digital Media Player
Dec 19, 2006 | Samsung Yepp YP-T7JX MP3 Player
106 people viewed this question
 Grubhead
Grubhead
