Question about Sony Audio Players & Recorders
Needing service manual for belt replacement. tc[k707ES
Needing service manual for belt replacement. No fwd nor reverse. thx TNGOPHER
3 Suggested Answers
SOURCE: Replacing drive belts on Sony TC-WR535
Its not easy, but doable. Steps are:
1. Remove top lid (4 screws on the side)
2. remove the back plastic mount on the mechanics (2 pink long screws on the top). The bottom are two plastic hook lock.  The mount pulls back and the belt and pulleys are exposed.  NOTE: It is the mount you are removing, not the tape deck itself.
In case you have to remove the printed board, here is the instructions:
Unplug all wires from the board.  Remove 3 screws.  hard part - release the board from the three white plastic lock. To do this, you crimp the the top and gently pull the board to the top.  Then slide the board backward to release it from the socket connection on the tape deck pcb.
Posted on Oct 31, 2007
I do not see pink long screws on my tc-wr535. Can you please be more specific on accessing drive belts. Thanks
Posted on Dec 02, 2007
TC-K61 Limited Edition. Turns on. Belt is spinning and the bottom mechanism comes up then goes back down. What's wrong?
A loose belt ,or a dirty mode select switch everything is timed the motor is allways turning but the play function is electro mechanical timed and if the belt is to loose its slipping on some points.
SONY TC K61 Service Manual free download schematics eeprom repair info for...
Apr 14, 2016 | Sony Audio Players & Recorders
Tip
My situation, tried solution and outcome same as Lucasforgot' comment....
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 29, 2009 | Acer Aspire 3680 Laptop
Wondering what has to come off to get to the timing belt
try books, there are lots of books used , real FSM on ebay for $20
its non trivial. not at all.
or online FSM. that car is one of the hardest, FWD. FWD are never fun to work on .
for $4 you can look
https://suzukipitstopplus.com/category/3-suzuki-service-manuals.aspx
or at mitchels
or alldata
or google (our friend ) the very first HIT.
lands me.... drum rolllllllllllllll
http://www.youtube.com/watch?v=P0vYvCSKTuk
Feb 20, 2013 | 2005 Suzuki Forenza
Troy bilt riding mower will not move fwd in gear
check the linkage adjustment
May 20, 2012 | Garden
I replaced capstan belt and now the reverse play doesn't work. I guess I didn't align the belt around the wheels the right way. I have a sony cassette deck tc-we605s. Do you have an image of how...
You do not need any special instructions- look at the flywheels when they are running- they are hooked to the capstan shafts. The capstan shaft have to go in opposite directions for auto reverse so just threat the belt to that this happens- the unit should then work.
You can get a Service manual from Hi Fi Engine maybe
Aug 26, 2011 | Sony Audio Players & Recorders
I have a very old Wizard (Western Auto) Front Tine Rototiller Model gis 6990 A27 with power reverse. I am looking for a manual or a diagram of the drive belt routing. (Patent #2903077). Any assistance...
Hi and welcome to FixYa, I am Kelly
Here is a picture of the belts installed.
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
NOTE the front fwd direction drive belt / closest to the motor is installed like any other belt. The rear belt for REVERSE direction has 1/2 twist. The idler pulley presses in for foward driving and pulls out against the reverse drive belt.
This should be what you need.
Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | Garden
Craftsman hydro gear transaxle problem
check the brake for sticking and dragging. check the bypass lever, make sure it's disengaged fully. did you just fix a flat rear tire? if so, the square key that links the axle and wheel fell out. do you pull a heavy garden cart around? that can stretch a belt and overheat the trans. last thought, check the belt and see if it came off a pulley, i know that should have been first but it's late and i'm tired. good night
Aug 11, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have a sony TC 530. Fast fwd and rewind work
You need to replace the motor run capacitor. It's a small aluminum can looking thing with three wires right next to the motor; they often leak paraffin wax into the bottom of the case when they overheat. Whether or not yours has leaked it's easy to replace if you can use a soldering iron. Search eBay for a Sony reel to reel 1.5uf 250VAC motor run capacitor - they're less than $15 and come with detailed instructions.
Please wait Image not available
Jun 14, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
http://www.eserviceinfo.com/index.php?what=search2
I am having the same problem with a Sony K717 ES. I found
this site above where they have the service manual for every tape cassette known to man. They ask that you make a donation to
a charity and then they will email you the pdf for free.
Sep 25, 2007 | Sony CASSETTE DECK Single Dual Cassette...
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
