Question about Sony Handycam DCR-TRV350 Digital Camcorder
The camera wont play back, it is starting to eat film, and the tapes get stuck. It seems that what was recorded with this camera wont playback on a different one either. Is it dead? Does it need a new battery? Any input will be appreciated.
  • 643 Answers
The heads are out of alignment. tape sensors are probably bad.as well as tape loader. flat rate if sent to sony would run around 180.
Posted on Jun 04, 2009
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
Samsung Camcorder eating tapes
the roller inside your camcorder might have dust dirt. try to use camcorder's tape cleaner to clean it.
Jun 28, 2009 | Samsung SC-L906 Camcorder
Sony handy cam
If your Sony tells you it is recording yet on playback there is nothing there other than a blank screen, I had this problem and this is how I solved it.
1. Clean the heads two or three times with head cleaning kit
2. Leave the tape door open, with tape out or in, and warm the camera up for about 2 hours minimum.
3. Put in a previously recorded tape and see if it will display that film. If not, repeat 1 and 2. Persevere.
4. Once Stage 3 works (you might have a few "dirty" lines on it for a few seconds, and it is playing normally, try recording.
This worked for me. The heads were dirty and the camera cold but I persevered and thankfully it is OK (but for how long?)
Hope this helps. It seems to be rooted around dirty heads and coldness.
Jan 03, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Canon xl2 playback
I DON'T THINK YOU HAVE A PROBLEM EXCEPT TRYING TO USE A GENERIC TAPE TO RECORD IN HD AND THEN EXPECTING IT TO PLAYBACK IN HD. IT WASN'T MADE FOR THAT AND WON'T WORK FOR HD. IF YOU ARE GOING TO USE A HD CAMERA, YOU NEED TO USE THE CORRECT HD TAPES TO EXPECT THEM TO WORK AND PLAYBACK CORRECTLY. WHY WOULD YOU BUY ONE OF THE MOST EXPENSIVE CAMERAS ON THE MARKET AND THEN USE A $2.00 TAPE AND TRY TO PLAY IT ON A $2000.00 CAMERA AND WONDER WHY IT DOESN'T WORK? BUY GOOD QUALITY TAPES.
Nov 14, 2008 | Canon XL2 Mini DV Digital Camcorder
Wont record or playback tapes
There you go. Thats a good way to get the problem solved.
Aug 08, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Camcorder has problems
I've had mine for about 3 years and just last year it started giving me playback problems....the screen would have blue stripes across it and sound won't play. I could usually fix it by rewinding and playing again...but it's not correcting itself right now... I hope I didn't waste 60000 yen on this c_c;
Oct 07, 2007 | Video Cameras
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Eating the tape
It sounds as if the takeup spool isn't doing it's job. It could be caused by a slipping belt or slipping clutch assembly. Unless you know your way around the unit (internally) I'd advise a repair shop have a look at it. BMW
Jun 07, 2006 | Sony Handycam CCD-TRV37 Camcorder
Can not playback past end of first file on my Panasonic PV-GS2
I'm not sure if this will work for you but, sometimes I try to play back some of my tapes and a blue or grey screen comes up instead, although this sounds odd, if I record something(for even one second) it will let me see my film. I know this can cause problems because you may end up taping over film but if it's the only way to see your film it's worth a try!
Jun 02, 2006 | Panasonic PV-GS2 Mini DV Digital Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
214 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
