Question about ASUS Intel 815E Chipset CUSL2-C Motherboard
Asus pentime 3/2 amd cpu but does not support win xp or graphics
  • 59 Answers
This board is compatible with xp but there is a problem of motherboard buffering. it may be capacitor of ur mother board have leakage.replace tham enjoy good luck plz vote on my comments
Posted on Sep 03, 2009
I am trying to download Minecraft on my new desktop computer windows 10.I try to load Minecraft up it always crashes with Pixel not forming. What graphic driver do I need to get Minecraft working????
Let windows install with compatibility mode for Win XP, or Win 7.
About Minecraft
A giant toy box, Minecraft is whatever you want it to be: a dungeon-delving adventure, a survival game, a multiplayer construction romp. It's all chunky blocks and imagination. You don't need much to run it, either: an Intel Core i3/AMD Athlon II and a GeForce 200 series/Radeon 5000 series is all.
Minecraft Minimum Requirements CPU: Intel Pentium D or AMD Athlon 64 (K8) 2.6 GHz CPU Speed: Info RAM: 2 GB OS: Windows XP or better Video Card: (Integrated): Intel HD Graphics or AMD/ATI Radeon HD Graphics with OpenGL 2.1 Click here for the latest video card drivers Sound Card: Yes Free Disk Space: 200 MB
Feb 23, 2017 | Computers & Internet
Recently ntly bought a new processor fx 6300 AMD
Could be a cable routing problem; interfering with other cables . Try re routing/separating the loom.
Oct 27, 2013 | AMD FX Six-Core Processor Model FX-6300...
Not sound
Dear raivo_bludja ,
please download your ASUS P5RD2-VM drivers from here and install
http://in.asus.com/Motherboards/Intel_Socket_775/P5RD2VM/#download
Thanks for your posting
Jun 24, 2011 | ASUS P5RD2-VM Motherboard
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
2600+ with ASUS MB A7V266-E/AA
Here is the CPU Support list from Asus Support, for the Asus A7V266-E,
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7V266-E/AA&product=1&os=17
Scroll down the list. 34th one down, that is listed.
1.Did you get the Athlon XP 2600+ that has a 266MegaHertz, (MHz), Front Side Bus? (FSB)
The AXDA2600DKV3C?
There is an Athlon XP 2600+ that has a 266MHz FSB, and one that has an FSB of 333MHz. <-This one Won't work.
Model number ->AXDA2600DKV3D will Not work.
Both are Thoroughbred A/B Core models.
The AXDA2600DKV3C has a 12.5x multiplier.
Your 1900+ has a 12x multiplier. (AXDA1900DUT3C) They both have an FSB of 133MHz. (Shown as 266MHz because AMD processors are 'Double-Pumped')
A.The AXDC2600DKV3C will not work. It has a 16x multiplier. (Thorton Core)
B.The AXDC2600DKV3D will not work. It has a 333MHz FSB. (Thorton Core)
C.The AXDA2600DKV4C will not work. It has a 15x mulitplier. (Barton Core)
D.The AXDA2600DKV4D will not work. It has a 333MHz FSB. (Barton Core)
E.The AXDA2600DKV4E will not work. It has a 400MHz FSB. (Barton Core)
2.Are the jumper blocks -> CPU RATIO, and SYSCLK, still set in the Jumper Free Mode?
By the factory default settings these jumper blocks, (DIP switches), should already be set to Jumper Free Mode.
The white DIP switches should be in the OFF position. (The white switches will be DOWN, towards the numbers on the jumper block CPU RATIO. They will be UP, away from the numbers, on the jumper block SYSCLK))
The CPU RATIO jumper block is right above the processor. It is a blue rectangular block.
The SYSCLK jumper block is down the motherboard, right below the AGP graphics card expansion slot. (And above the first PCI expansion slot)
If those two jumper blocks are not set to Jumper Free Mode, set the DIP switches in the jumper blocks to this setting.
Now go into BIOS Setup. In the main menu use the Right Side Arrow key on your keyboard, and highlight Advanced.
If -> CPU Speed is set to Auto, you won't have access to set your CPU parameters. If it is set to Manual, you will see them. If it's set to Manual, write down the headings, (CPU:System Frequency Multiple, System/PCI Frequency (MHz), and so on) Write down the numbers to the right of these headings. If something goes wrong, you can go back into BIOS Setup, and change them back.
1.CPU:System Frequency Multiple should be
12.5X
2.System/PCI Frequency (MHz) should be
133/33
3.System/DRAM Frequency Ratio should be
(Auto)
4.CPU Vcore should be (1.750)
5.CPU Level 1 cache, and Level 2 cache should be (Enabled)
6.CPU Level 2 cache ECC Check should be (Disabled)
7.BIOS Update should be (Enabled)
8.PS/2 Mouse Function Control (Auto)
9.USB Legacy Support (Auto)
10.OS/2 Onboard Memory >64M (Disabled)
Leave the rest alone.
The AXDA2600DKV3C uses 1.65 volts, has a 12.5 clock multiplier, and a 266MHz FSB. (You will see 133MHz, and set all your settings to 133MHz. AMD processors are 'Double-Pumped'. Intel processors are 'Quad-Pumped')
Aug 10, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
Asus a7n8x MB and ram
i just checked & yes you can from what i was reading
Mar 30, 2008 | ASUS EN8500GT HTD DDR II, PCI Express...
Pc upgrade !
IAN.S
Where you need to be is on Asus web site. Your board can handle ONLY; Athlon XP 3200+(400 MHz FSB)(Model 10)(Barton), AXDA3200BOX
With that CPU you must also have bios version 1004.
Check PCB and BIOS versions before flashing BIOS!
asus A7N8X supported CPU click here; http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7N8X
Since you seem to need your manual. Click the link:
http://dlsvr01.asus.com/pub/ASUS/mb/socka/nforce2/a7n8x/e1859_a7n8x.pdf
You do not have an intergrated video card. You have a 1.5v 8x
AGP video slot.
I suggest you call Asus & make sure your CPU model AXDA3200DKV4E will be supported over model AXDA3200BOX.
You can call Asus tech M-F EST at 812-282-2787.
Good luck & Have a great day!
Mar 16, 2008 | ASUS A7V8X Motherboard
ASUS Intel 815E Chipset CUSL2-C Motherboard Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
