Question about OKI C5200n Laser Printer
I have a HP Photosmart C7250, that doesn't print properly!
I'm trying to print an essay out and it only prints 1/10 of the page, then stops and still says "Now Printing..." but like an hour later it spits it out with only 1/10 of it done! I have Windows XP Pro, 1GB of RAM, and it is almost 4 years old. I tried turning the printer off, unplugged it, waited 30 seconds, then plugged it back in...and nothing, same problem. My computer says it printing fine, but it's not!
  • 225 Answers
Do you have the right drivers installed if not heres the link to get them http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=it&cc=it&product=3382185&lang=it& just go there picking your operating system and download the drivers, that website also has software for it, it sounds like your printer isnt sending the right signals to the computer thats prob why its doing that i could be wrong thats just one solution
Posted on Jun 04, 2009
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
HP Photosmart C7250 lines in photos
Replace print heads.. For draft or letter work you can adjust with this print heads, but photo prints you need good healthy conditioned print heads.. as per you info you did every thing rest only thing to replace..
Jan 09, 2012 | HP Photosmart C7250 All-In-One Thermal...
I connected my hp C5180 to my pc then printed a test page, it started to print and hasn't stopped. It just keep printing pages of code. How do I stop this???? Tried cancelling, tried turning off...
YOU NEED TO GO TO PRINTERS...AND CHANGE HOW PAGES YOU WANT TO PRINT...AND TAKE THE PAPER OUT OF PRINTER, SO IT DOESN'T USE UP ALL YOUR INK!
HOPE THIS HELPS!
Aug 31, 2011 | HP Photosmart C5180 All-In-One InkJet...
My HP C7250 inserts a blank page between every printed page. Windows Vista PC.
Perhaps this is a characteristic of the document being printed: Manual paper feeds in addition to the automatic paper feed characters? Use the word processing program matching the document to remove the unwanted paper feeds.
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
HP C7250 PRINT JOB REMAINS IN QUEQ THEREFORE WONT PRING
I responded to this on another page turn off printer at power. Turn off or reboot PC then the ques is emptied. Follow my other suggestion for using the right driver and setting up the prnter again in Vista
Jul 28, 2009 | HP Photosmart C7250 All-In-One Thermal...
Last line getting cut off when printing
go to control panel and click on printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Mar 31, 2009 | HP Photosmart C7250 All-In-One Thermal...
Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Aug 02, 2008 | HP Photosmart C7280 Laser Printer
OKI C5200n Laser Printer Logo
131 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
