Question about Panasonic TH-42PA20U/P 42 in. Plasma EDTV
TV just shut off....
My screen went black; like the tv just shut its self off. power light blinks 10 times. is is a bad accept point a loose circut...short circuit. Can I fix this or do I have to send to be serviced...how much will that cost?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Nop , u may need the g board , for this repair u need a tv tech to do the job
Posted on Jun 04, 2009
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Panasonic Viera 42" Plasma, 2 yrs old, Model # 42PZ80U, screen just went black and I cannot bring it back. The red light is blinking 10 times.
Typically this means you've got a power supply that went bad. I've been doing research for a potential class action lawsuit on these "blinking lights of death" problems that the Panasonics are having and that is usually why the tv will show 10 blinks. Occasionally another component inside the tv can be what caused the tv to shutdown and show the 10 blinks.
I'd like to hear more about your experience with the television and any contact you've had with Panasonic in an attempt to get the television repaired. If you're inclined to share your story with me, please contact me at kiaeger@levjen.com.
Oct 12, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
It turn off it self
Hi
Thanks for using FixYa. Red light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. If you want to do it yourself all this is only recommended if you have electrical expertise and know how to solder/re-solder components if not then you should always contact a qualified repair tech. for the same.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 29, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Plasma TV - intermittent blinking
Power supply failure. Either a capacitor went bad, or there is a loose solder joint near the big transformer on the power board. I would guess loose solder connection.
Nov 14, 2008 | Televison & Video
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Panasonic TH-42PA20U/P 42 in. Plasma EDTV Logo
196 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
