Question about Poulan Pro Chain Saw 46cc 20"
I have a brand new Homelite Pro 46cc 20 in. chain saw. I have never even started it up. I cannot figure out how to open the Tool less clutch cover can ya'll help me?
    Master:
  • 401 Answers
Press in on the clutch cover lock knob and rotate
counterclockwise until the clutch cover can be
removed. You will see the arrow on the outer cover that will direct you in the right direction.
Posted on Dec 31, 2014
  • 106 Answers
Go to page seven:
http://72.3.225.179/manuals/545186803en_r3.pdf
if this helps please rate me, thanks.
Posted on Jun 04, 2009
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
How to adjust a poulon pro chain saw 46cc 20" chain tighting
First, I'd read the manual if in doubt. No matter the type of adjuster, tool-less or not, you loosen the bar nuts, tighten the adjuster until the chain just touches the bar on the bottom (while holding the bar nose up) then tighten the bar nuts. Chain should move easily.
Re Poulan chain tightening. Be sure it's oiled and sharp, of course.
Aug 20, 2014 | Poulan Pro Chain Saw 46cc 20"
How do i remove and replace the clutch assy on my 4620av pro
The clutch is spun onto the crankshaft with a left hand thread, there is a special tool that fits into the two cut a ways in the clutch centre so as to fit a 19mm socket and jar it off against compression, the tool is part no. 530031112.
Aug 27, 2011 | Poulan Pro Chain Saw 46cc 20"
JUST BOUGHT A 20'' POULAN PRO TENSION A CHAIN
the adjustment screw near the end of the bar( next to the engine) needs to be turned in to tighten the chain just don't tighten it to much
Apr 04, 2010 | Poulan Pro Chain Saw 46cc 20"
How do i loosen chain on my poulan 46cc 20 inch chainsaw ?
Is it fitted with a tool less adjustment device? See Operator's Manual. Normal configuration as below:
d914aed.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Oct 12, 2009 | Poulan Pro Chain Saw 46cc 20"
I have the same issue
Very likely it has oil on the interior of the clutch assembly. Wash out with carburetor cleaner from the auto parts store and blow out with compressed air. Hope that helps.
Jun 24, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 3314 piston change, special tool needed???
Needle nose pliers. You would normally use a new lip when reinstalling it.
Mar 16, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 46cc has very little power
you need to adjust the gas an air on those two little screws on the carburator
Feb 03, 2009 | Poulan Pro Chain Saw 46cc 20"
How do I remove the clutch on an Echo chain saw??
Backwards to the rotation of the motor, all you need are basic tools to do this.
Dec 16, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
390 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
