Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Red light blinks 5 times!!
I have a pt-53wx53 projection tv and i have the same problem!!! turn the tv on and it turns right off but instead of having the light blink 3 times it blinks five times!!! what does this mean?? please help!!
  • 22 Answers
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Posted on Jun 04, 2009
10 blinks Sony rear projection
If your model is a KP57WS520 and the light blinks 10 times thats a fairly common issue and there is a repair kit for that error at the following link it bottom of the page http://tvrepairworld.com/rear_projection_tv_circuit_boards/rca_circuit_boards
Apr 03, 2013 | Panasonic PT-53WX53 53" Rear Projection...
Why is my panasonic hdtv 1080i on off switch blinking red
thats usually an error code. How many times does the light blink?
Apr 02, 2013 | Panasonic PT-53WX53 53" Rear Projection...
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
It won't come on the red light blinks 5 times then after about 5 seconds blinks 5 times again and repeats..
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Jan 11, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Aug 14, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53 hdtv
Check the voltage across R517, should read about 12v if not replace C524 which is your AC gournd return and possibly D509 feed diode. I suspect that you get enough voltage to trigger the relay but just before B+ happens the 12v line drops well below the trigger voltage and the relay re-opens.
Bill
Oct 29, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Mar 25, 2008 | Televison & Video
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
595 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
