Question about Canon PowerShot SD1000 Digital Camera
Lens Struck Lens of the camera has been struck and is not going inside even after removing battery or memory card.when ever I start my camera it says "LENS ERROR RESTART CAMERA"
  • 1 more comment
  • javacoder Nov 24, 2007
    I also have the same lens struck problem, lens is not going inside. It gives "lens error , restart the camera" message and turns off itself. Do anybody have any solution for this problem?
  • Anonymous Jan 20, 2008
    All i can say is "Same Problem" Can't imagine Canon doesn't realize this as a product issue and not support the consumer and address it. This Lens problem is all over the internet with solution I'd rather not try unless I'm ready to throw the camera away.
  • sandysandy Feb 29, 2008
    If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
    If your camera is out of warranty , or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
    Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
    1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
    2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
    3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
    4) Try forcing the camera lens:
    Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
    Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
    If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
    Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
    5) If that doesn't work, there is an online guide for dismantling
    Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
    There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
    - Bulgarian guide
    - Estonian guide
    If you found these Canon repair instructions useful and have managed to solve the E18 problem, write us about how you did it. We're looking forward to your emails. Also, please use the links bellow to bookmark us on Del.icio.us and Furl.
    Bookmark This Page on: Del.Icio.Us / Furl
I had the same problem for several dads. I know this sounds silly, but after reading about numerous people having the same problem and without many solutions offered, I tried the somewhat weird suggestion of shaking my camera vigorously around and it worked! I promise.
Posted on Nov 15, 2007
Lence erro & restart camera
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Canon service as you do not have to run around for spares.
Jun 14, 2011 | Canon PowerShot A480 Digital Camera
My camera powershot A560 .... lens error !!
May 28, 2011 | Canon PowerShot A560 Digital Camera
The camera will turn on however the lens will not come out and it makes a bleeping noise 3 times. After this the camera turns off. We have removed the memory card and battery and nothing works. Any ideas?
get estimate before you decide. It will be good to have it checked at the Samsung service as you do not have to run around for spares.
Apr 23, 2011 | Samsung ST45 Digital Camera
Zoom stuck on camera wont go back in
get estimate before you decide. It will be good to have it checked at the service center as you do not have to run around for spares.
Apr 15, 2011 | Cameras
Camera shows lens error....will not open or close
get estimate before you decide. It will be good to have it checked at the service as you do not have to run around for spares.
Apr 06, 2011 | Cameras
The lens extends and retracts constantly after turning it on. Battery has a good charge.
It is also possible that the mechansim is struck .Use some high pressure jet air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at any camera/Kodak service as you do not have to run around for spares.
Mar 13, 2011 | Kodak EasyShare P850 Digital Camera
Lens error
get estimate before you decide. It will be good to have it checked at the Nikon service as you do not have to run around for the damaged spares.
Jan 06, 2011 | Nikon COOLPIX S610 Digital Camera
Camera error#e 45
The Possible error is due to failure of the control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
To open the camera without good experience is not recommended and might tamper the delicate unit. So
get estimate before you decide. It will be good to have it checked at the Kodak service as you do not have to run around for spares, even if it can be confirmed.
Nov 24, 2010 | Kodak EasyShare V610 Digital Camera
Lens wont go in or out I get error code 12 help
get estimate before you decide. It will be good to have it checked at the HP service as you do not have to run around for spares.
Nov 19, 2010 | HP Photosmart M420 Digital Camera
When i turn my camera on i get amessage lens error restart camera.
The lens error is due to failure of the lens control system. It will be good to have it checked at the Canon service as you do not have to run around for spares.
You can remove battery and card replace battery and while switching on tap the lens hood on your palms so as to disengage any dirt or mechanism being struck.
Oct 07, 2010 | Canon PowerShot SD1100 IS Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
168 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
