Question about HP DeskJet 940c InkJet Printer
Replaced cartridges and the cyan/blue ink does not print ... it is a genuine HP cartridge... could the blue ink be dried up, what can I do... using a Macintosh
  • 10,515 Answers
Usually genuine Hp catridge does not dry up until and unless you might have kept it open for many weeks and never used.
If that's the case, sorry to be a bearer of bad news, you need to replace catridge.
Thanks.
Posted on Jun 04, 2009
Epson ink cartridges, always empty?
Epson has gone to great pains to ensure that third-party cartridges dont work. They really did a good job. Sometimes their printers wont even recognize genuine Epson cartridges. I saw a CX8400 with a brand new cartridge claim it was out of cyan ink after printing one 4 x 6 photo. Then it would recognize any cyan cartridge. It had to go back to Epson for replacement. Sign in China com Online Wholesale for AD Signage Product
Apr 22, 2014 | Office Equipment & Supplies
I replaced my ink cartridges on my hp photosmart d7260 but the cyans are not printing only the other colors, i have ran the test and clean the heads as stated, also i have unplugged the printer and...
Try using this steps.. I hope it will work, because it works for me. :)
  1. Make sure that the printer is on.
  2. Open the cartridge access door.
  3. Take out the cyan ink cartridge on the printer.
  4. Get a wet clean cloth.
  5. Clean the electrical contacts on the ink.
  6. Dried the ink using a dry cloth.
  7. Put the cyan ink cartridge on the printer.
  8. Close the cover.
  9. Please make a test by going to setup menu > tools > self-test report.
  10. If the cyan ink still doesn't print.
  11. Clean the printhead and align the printer by going in to setup menu > tools > clean printhead or align printer.
  12. If the issue still persist.
  13. Replace the problem Ink cartridge.
After replacing the ink cartridge and your still having issues w/ it. Service the printer or contact HP's printer support department for more options. 1-800-474-6836
Good Luck :)
Feb 06, 2011 | Office Equipment & Supplies
Cannot print in a cyan color after having the cyan cartridge refilled. How do I cure this problem?
Often these newer style of ink cartridges utilize a chip which makes it that much harder to find a good compatible ink cartridge to work.
You can follow this link for a run down of replacement ink cartridges, genuine brand HP or Compatibles and give a replacement cartridge a try to see if it fixes it:
http://fusers.com/index.php?type=extended&make=12&type=714&model=32399&dispatch%5Bproducts.search%5D=Search
Jan 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Replaced both print cartridges but print is faded blue
Solution: There are a number of steps you can take to solve this problem (in order of easiest & least expensive first).
1. Make sure you have tried printing a nozzle check and you've carried out all the maintenance tasks that the manual alows (align print head, clean print head etc).
2. Your cartridge may be faulty. Ink cartridges that use non-genuine ink are of variable quality and you use them at your own risk. Even genuine cartridges can expire if used after the expiry date. Bad ink can clog your nozzle. It may be that you have a dried-out ink cartridge - try another one if you have one handy.
3. The print head may need cleaning. There are Canon print head cleaning kits available (use Google top right) or you could try doing this yourself - some people have had success immersing the print head (not the cartridge) in cleaning alcohol, warm water or using compressed air to gently blow through the nozzles.
Apr 30, 2010 | HP OfficeJet 7110 All-In-One Thermal...
The CYan head doesn't fully operate Brother MFC 685
Hello sir; Try to put this cartridge inside the warm water for 5 to 10 minutes and put it back to the machine, sometime it work, sometime not, just try it out.
Feb 05, 2010 | Brother MFC-685cw InkJet Printer
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
Blue ink - printing problem
Your Cyan cartridge is empty and need replacement. Maybe you can clean head of Cyan cartridge with alcohol but symptoms are the empty cartridge!
Good luck.
Sep 11, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP DeskJet 940c InkJet Printer Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
