Question about Microsoft Xbox 360 Console
Xbox game disc has ring burned in and won't play
    Novelist:
  • 174 Answers
Either your laser has burnt it, or it has been rubbing and the mechanism needs re-aligning. We offer all console repairs. FixMyConsole
Posted on Jun 04, 2009
My xbox keeps scratching all discs and wont play them.also tray is loose .when disc is in the screen says reading then makes a noise then says open tray
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally required to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 disc repairs, visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Apr 02, 2010 | Microsoft Xbox 360 Console
Tip
Check to see if there are any scratches or laser burn marks on the discs....
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Apr 03, 2010 | Video Game Consoles & Games
When playing games the xbox screen freezes.
www.discREPAIR.ie
Hope this Helps!!
Mar 07, 2010 | Microsoft Xbox 360 Console
Saints row 2 keeps freezing just after the disclaimer bit on loadup y'know where it says loading etc and it freezes on 5% and then i have to shut the xbox off please help its the one game my xbox wont run...
The driver on your xbox could be corrupted or the disc's are too scratched, Try getting the discs buffed out. Sorry to hear.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | THQ Saints Row 2 for Xbox 360
Cannot play fifa 10, disc is clean and doesn't look scratched, all other games are playing. console says to restart which has been done a few times
There may be no actual standard scratches visible on your disc but a common problem that Xbox owners are reporting is, if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular bands or marks around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on Xbox & Xbox 360 disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters, or send your discs for repair.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Feb 13, 2010 | Microsoft Xbox Console
Damaged Games
www.discREPAIR.ie
Hope this Helps!!
Feb 04, 2010 | Microsoft Xbox Console
Halo ring on disk.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is usually required to repair any scratches or laser burn on discs.
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters or to get scratched discs repaired back to "As Good As New Condition".
Hope this Helps!!
Dec 29, 2009 | Microsoft Xbox 360 Console
How to repair nba 2k9 for xbox 360
When I have problems with scratched DVD's or games, I use the scratch remover cream that goes on your disc, Leave it on for a few minutes to dry, then wipe it off with a very smooth cloth... Its about $7 or $8 I think.... Good Luck, Like I said this usually works fine for fixing scratched discs
Oct 18, 2009 | 2K Games NBA 2K9 for Xbox 360
Xbox360 defective and ruined games.brand new console and games.
Hello.
Xbox DVD-Drive's often scratch circles into your discs and some even got malfunctioning lasers that will burn rings into games.
To prevent the circular scratched from happening avoid moving your console at any time while it is running however it often also occurs just in regular use especially for older consoles with Hitachi or Samsung drives.
As far as I know Microsoft replaces discs that were clearly damaged by a console free of charge, at least here in Europe they do.
Try calling Xbox Customer Support and ask for a replacement it is worth a try for sure even if they shouldnt replace it they will at least give you a 1-month subscription for Xbox LIVE in exchange.
If you can get the console replaced as well depends on the support person you are talking to but usually they charge you for that if you want to fix the drive yourself, open up a PC drive and take the foam pads outs and install them in the 360 drive this will prevent the discs from getting scratched they just didnt use these pads in the Xbox for some reason which led to these problems...
I hope this helps and Good luck!
Kind regards,
Wilhelm@Xboxexperts.com
Dec 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
168 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
