Question about Epson Stylus Pro 9600 InkJet Printer
Epson 9600 40x60 Print Job Quitting Early
Quitting Print Job Early: I have a similar printing problem when printing a 42x61 image, The image prints out approx 45 inches and then just stops. tried 3x.
I am printing on an 4GB iMac OSx10.5x over a network to an XP2003 server in my basement to which the Epson 9600 is connected via USB.
Using Gutenprint Epson drivers, all other printing works fine, just large jobs stop.
I've already tried reducing the resolution by half to approx 150dpi, but the print still stops in the same spot.
When it happens the spool files on the XP server are gone when this error occurs, and my MAC console says E [03/Jun/2009:18:37:27 -0400] [Job 13] Error writing spool: ERRSRV - ERRerror (Non-specific error code.) I [03/Jun/2009:18:45:00 -0400] [Job 13] Completed successfully.
Is this an XP issue writing to the remote spool?
Will going to an Ethernet USB print server help?
Do I need an expensive RIP?
Any suggestions / help will be much appreciated!
ohms
  • 1879 Answers
SOURCE: Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Posted on Jan 26, 2008
SOURCE: New Epson RX595 won't print
Apparently the latest software doesn't work with Leopard 10.5.2. I uninstalled the Epson software and installed the earlier version [driver version 3.88] that come on the Installer CD with the printer. Printing now works.
Posted on May 19, 2008
  • 39 Answers
SOURCE: Printer is a Canon MP470 all-in-one, USB
Is your printer hooked up to your network?
Make sure all your settings are correct and try connecting the printer directly into your computer. Then print if it does not work still then comment back and I will be glad to help.
Hope this helped.
-Ryan
-Please rate if this helped
Posted on Feb 19, 2009
57 varieties
  • 1653 Answers
SOURCE: Epson R380 connected to PC can't use its driver on MAC OS X 10.5
Make sure that you have only loaded drivers for XP and that they are the latest ones instead of the MAC OS ones at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=72086&prodoid=63059189&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=17&y=12
Posted on Aug 29, 2009
podita
  • 324 Answers
SOURCE: My epson Cx5500 won't print anything but no errors!
PLEASE DO RE-INSTALL THE DRIVERS
Posted on Mar 24, 2010
I suspect this will be a tricky one! I am printing from a new iMac / CS5 setup. I am using OCP inks and Ilford paper. I am printing the same images to both machines. The print settings are identical....
hi Anthony, i spent a month trying to figure out a similar problem with an epson 2200. Now, the printers are different but not that much, and, the changes in paper and ink gave me "some" color issues but not as bad as what i was getting. your problem seems very similar. i run a PC so this is similar but not exactly the same. what i found was that a Magenta/ violet cast was due to double profiling. I could verify that i had the correct settings but i was wrong! I print from CS3 into the epson 2200. What i found was there is an error(no one is talking about) in the printer driver. You cannot shut off the color management completely! Assume this scenario, you are printing with CS3 applying your profile in CS3. Make the settings in CS3 as normal, then you are directed to the printer settings. Go to the print driver and make the selections for ICM Color, and select "no color". The KEY is to make sure you do this step LAST , make sure to click on the "apply" button, then "Close". Once you make the selection of "No Color" do NOT click on anything else. If you change screens in the print driver once you select "no color mgmt" the driver CHANGES your settings. ANY settings in the other pages in the print driver cause the driver to apply a printer profile, this effectively "double profiles" your photo print causing the magenta cast. None of this should happen if the driver was created correctly but there it is! It took a long time to test and verify but it is as i stated. Once i got it sorted out my photos are excellent ALL the time. Good luck, worm1855.
Nov 21, 2010 | Epson R800 InkJet Printer
It is offline and will not print. Last print job
check the printer cable, try to change with other cable, or you can try to reinstall your printer driver.. hope these will help
May 04, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Extreme color lines in all printing: text and images. the printer has never been great at printing images but has now started to print with bright color lines through any print job.
Have you been using Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Sep 29, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Reset Epson DFX-8500 Matrix Printer
Remove power cord for at least 10 seconds AND delete print job manually from Windows(?) Open Control Panel>Admin Tools> Services. Stop print spooler service. Delete contents of c:\windows\system32\spool\printers folder, restart print spooler service, plug printer back in.
Aug 14, 2009 | Epson DFX-8500 Matrix Printer
My Epson Color 3000 will not print the entire image. It prints well from left margin to center of page and dosen't print to right margin. Half of the image dosen't print.
see the printer settings. adjust the page setting or try to see the print preview before printing. if the problem still persists visit the mentioned link for free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Epson Stylus Color 3000 InkJet Printer
Photos printing too dark
try editing the photo.. more brightness, contrast etc etc.. see if it will also print brighter... if it still prints the same i guess its time to throw the printer back to epson
Dec 26, 2008 | Office Equipment & Supplies
HAVE CX11NF...I believe there are faxes in memory.....how do I get them to print...I went to fax mnode/memu/printing report/memory job info....result is printing job is flashing inb memory job window...and...
You have an early model unit, there is a known glitch in the firmware and you will need to contact epson to update the firmware. The glitch causes the unit to recieve faxes, but it will not transmit them to print. Unfortunately, when you get the firmware updated all of your faxes will be lost anyway. Epson is well aware of this problem and should update the firmware for nothing under warranty, even if the unit is out of warranty. Contact epson in your country and get them out to fix the issue. If they try to charge you, let them know that this is not the fault of the user and that they have known of this issue for a few years now. Trust me, they will come to the party if you scream loud enough.
Gremlin11
Dec 03, 2008 | Epson ACULASER CX11NF All-In-One Printer
Will not print Photoshop file
Have you check to see if this is a postscript driver you are using?
Sep 29, 2008 | HP LaserJet 1320 Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Quitting job early
Photoshop CS3 only allowes prints till 30.000 pixels in each direction. That's a kind of bug. You can lower your reslotution or buy an expancive RIP.
Apr 01, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
241 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
