Question about Motorola Mobility HS850 Consumer Headset
Might light on my headset won't stay blue! Can't keep blackberry and headset paired
  • 13,433 Answers
Have you charged the headset? could be low on battery power.
Recharging— When you hear five rapid high tones through the headset speaker, repeated
at 20-second intervals, the headset battery needs to be recharged.
when its properly charged
Pair them again:
  1. put the headset into pairing mode. - the headset indicator turns on
  2. with the headsets boom closed press and hold the multifunction button E until the headset indicator turns on (about 3 seconds) - The indicator remains lit
  3. Release them button, then open the headset boom.
  4. Perform a device discovery from the phone. - the phone will dispay device found.
  5. select motorola hs from the list etc..
  6. when prompted by the phone, enter the passkey 0000 and confirm to pair the headset the the phone.
Pairing is successful when the headset indicator flashes 10 times rapidly.
If the headset indicator light goes off, then the power is off, this could be caused by empty or bad battery.
The indicator should flash at a 3 second interval, indicating that its on stand by mode ( not on a call )
The indicator will pulse at a 8 second interval when the headset is connected (on a call)
Five rapid high tones, repeated every 20 seconds = low battery
How to Charge:
Posted on Jun 04, 2009
I cannot pair my blackberry curve 3G with my Wireless Nokia headset BH-503! It was working until I paired it with another nokia 2700 and after trying to pair it with my blackberry curve 3G again, it...
It is paired with the Nokia 2700.
From the manual (Click here to get it) page 11;
To clear the pairing and volume settings, switch off the headset and press and hold the multifunction key and press the volume up key until the indicator light alternates red, green and blue three times.
Feb 05, 2011 | Nokia BH-503 Bluetooth Headset
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I want to connect my Blue tooth device to my BlackBerry 8530 and I don't know how- This Bluetooth device used to be connected to a cellphone I had over a year ago- Now I have the NEW BlackBerry 8530... but...
In order to pair this headset with your BlackBerry, you need to place the headset in to pairing mode. To do this, press and hold the talk button until the indicator light turns blue and stays lit after blinking.
After you do this, go to the bluetooth setup area and search for a device. Once it locates your headset, it will prompt you for a PIN. This PIN should be the factory default, 0000. I hope this helps!
Mar 21, 2010 | Samsung WEP650 Bluetooth Headset
I have a new Blackberry and can't pair my WEP410
You don't have to. So long as you don't use or have the other phone turned on you won't have a problem. To delete a device you have to go to your Bluetooth icon and check your paired devices..click it and delete. Also...if you can't get it to pair. Codes is 0000 or the last four digits of your phone number. Make sure the headset is in "Pairing mode" which is when the blue light stays lit. And you do that by holding the call button. Or call button and both volume buttons. If its a flip out headset then hold the call button and flip open until the light stays lit. Good luck. Rate plz.
Jan 10, 2010 | Radio Communications
I want to pair the motorola H500 to my blackberry pearl. i cannot get the bluetooth in pairing mode?
-Be sure the headset is fully charged.(plug it in till the light turns off.)
-Hold the talk button down for 4 seconds or until the blue light goes solid (not blinking.)
Now the device should be ready to pair with your Blackberry. It usually only stays in pairing mode for a short while (approximately 90seconds)
Jun 30, 2009 | Motorola Mobility H500 Wireless Headset
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Dec 14, 2008 | Nokia Bluetooth Headset BH-207 Wireless...
Plantronics 520 will not pair
"Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue."
Dec 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
