Question about Cobra 29 LTD CB Radio
Not getting out or receiving well
I get a radio check sometimes and acassingly talk but i can hear it thru my truck speakers.i have a wilson ant and my cb is stock\my swr is below 2
  • cott Jan 08, 2008
    I can hear others really good, but I can't tell if i'm getting out. No one will reply when I ask for a check.
I had same problem i bought new mic and problem resolved
Posted on Feb 01, 2008
  • 126 Answers
Don't worry, I know my cb gets out and still people do not want to give radio check much at all. If you have a buddy with a cb set up, swing by his place and do a distance check between you two. The only other way to tell if you are getting out, without a radio check, is to have a meter inline to see if you are transmitting.
Dean
Rollin CBs
Mt. Vernon, TX
Posted on Jan 23, 2008
Make sure your p.a. is turned off
Posted on Jan 05, 2008
I can no longer send or receive anything but people can hear me key up but that is all and my ant light is on
Check you swr's .. sounds like you have High swr's if its not txmiting.. Have the SWR's checked.. should be free at any good radio shop.. when that ant light comes on do not talk on it.. it will damage the radio over time..
Sep 21, 2011 | Cobra 29 LTD CB Radio
My cobra 29 ltd is in a ford truck with a over head camper. i put a magnet mounted wilson 1000 watt ant (4ft.) on top of the cab. I cannot get any squelch to work I did a radio check i believe i was heard...
Assuming you don't have the manual,basic controls for receive are to make sure the switch next to the meter is set to s/rf,switch for cb/pa is set cb,knob for rf gain is at max, squelch knob is fully counterclockwise..squelch can be adjusted if ya don't want to hear static but will start cutting out weaker signals.If none of the above works,try plugging in an external speaker to the jack on the back of the radio,if ya still don't hear anything,check that antenna coax is screwed in tightly in back of the radio.Next step after all that would be the microphone,is the stock mic,power mic..if it is the original stock mic that has not been rewired in any,then I would suggest taking radio to qualified cb repair shop,bring mic with you to shop so they can check it too,in fact I would bring the truck also so they can check antenna and adjust it if needed...Good luck
Sep 04, 2011 | Cobra 29 LTD CB Radio
Cb radio
As for me ,the Wilson 1000 or Wilson 2000 are the best mobile antenna for a mobile. I have out talked a lot of base antennas with them, just put it on the top of car in the center or trunk, or middle of cab of truck, with a good SWR and you are talking and receiving. great antenna. ...hope this helps..
Jun 01, 2010 | Cobra 29 LTD CB Radio
Can't talk about 2 miles ,swr is good
If your talking at least 2 then it sounds like it is the antenna. Any antenna should talk 10-12 miles on a good day, no matter what radio you're using. So I'd get a second look at that system.
May 30, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
I also have another cobra 29 ltd classic and it works fine but i cant talk or hear what other factory cb's can hear, it is supposed to be tuned and peaked and i have a wilson 2,000 antenna, and i cant talk...
nearly all problems are caused by poorly tuned or untuned antennas. a good antenna system with a cheap stock radio will out perform a great tuned radio with a bad antenna system any day of the week. if you dont believe me, check the firestik antenna website's tech notes. or wilson's tech notes.
Sep 23, 2009 | Cobra 29 LTD CB Radio
Poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
Nov 18, 2008 | Connex 3300 240-Channels Base CB Radio
Have prob wit cb radio
I WOULD CHECK THE COAX CONNECTION @ THE ANT HAVE SOMEONE MOVE THE WIRE AT THE ANT CONNECTION WHILE YOU LISTEN INSIDE IF THERE A LOOSE GROUND YOU WILL HEAR IT ON THE RECEIVER SIDE.. ALSO CHECK YOUR MATCH WITH AN SWR METER.. DON'T TRUST THE ONE ON THE RADIO IF YOU HAVE ONE GOOD LUCK
May 04, 2008 | Radio Shack TRC-447 CB Radio
Sending and Receiving sounds like "penuts teacher"
maybe its your coax i had that problem before
Feb 21, 2008 | Cobra 29 LTD CB Radio
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Poor reception
Sounds as though You have a bad antenna system ( may be bad coax ). Unless there is infact something wrong with the radio ( this is unlikey) you need to have the SWR's ( Standing Wave Ratio ) checked and trouble shoot the antenna problem. Although the ST seems to be ( In my opion ) the worst recieve radio Cobra could develope, they normally work to a good standard. As for the meter not working, this may also be lack of a good signal from the ant problem. If infact the antenna and coax is good, then take a close look at the output ( final ) transistor. If it's shorted, it doesn't receive well nor does it transmit well.
Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 03, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
200 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
