Question about Dell Dimension 4600 PC Desktop
Dimension 4600 bios dosen't see SATA HDD
Story goes like this: iTunes was uninstalled and the system crashed. Can see that HDD (it's original drive) is not detected by bios. Tried a different drive, same problem. Any drive plugged in to IDE1 goes invisible... Magic! Been fixing PC's for years, this is the first one I can't repair. Any ideas?
  • Zach
    Zach May 11, 2010
    will the computer turn on, show the bios and are the cd or dvd drives working?
  • Greg Margossian
    Greg Margossian May 11, 2010
    Have you flashed the BIOS? I'd either flash it or removed the battery for a while (while unplugged). This should revert the BIOS back to defaults.
    President:
  • 2,559 Answers
Just reload the SATA drivers,you can use an xp disk and select F6 when ask if you want to install 3rd party driver,Just have the driver disk ready when it ask for it and use the second repair option instead of the first to prevent a total reinstall.
Posted on Jun 04, 2009
Sata hdd not recognized
Assuming the the HDD is working fine, go to the BIOS settings and you can turn SATA mode to IDE mode to bypass the issue.
Apr 14, 2016 | Genuine DELL WG261 Motherboard For the...
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
My computer cannot find he primary hard drive
Hi friend,
this is not your system problem. it is your wire problem. You need to change your hard drive cable then try.
Dec 17, 2009 | Dell Dimension 3000 PC Desktop
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
Hi My hard drive crashed can it is old can it be
Most likely scenario is the drive is dead, but also the BIOS on your computer is old itself, I believe there are a few BIOS upgrades available for that model, might want to check with Dell support site. If you have access to another computer, there is a way to check your drive. Go to a computer retail store or on Ebay, but a EIDE/SATA to USB adapter. This will allow you to take a hard drive out of the case and attach this adpter to it and plug the usb side into another computer, laptop, doesn't matter...that computer will read the drive as an external hard drive....if the drive is indeed still viable. If it is, this would be a good time to save your files to the other computer for safe keeping until you can get your other system back on its feet.
Oct 10, 2009 | Dell Dimension 4600 PC Desktop
I WANT TO INSTALL LOCAL DISK D ON MY COMPUTOR?
i lose my local disc d in my komputer,my dvd rom can read a disc.how can i instal
Sep 16, 2009 | Dell Dimension 4600 PC Desktop
Windows can't install because it says it can't find a hard drive. Setup indicated both HD's are there and working. Installing Windows 2000 from Disc. Changed boot sequence so Rom boots first. Windows loads...
Check for sata drivers, if it is system is shipped with SATA hdd, need to install SATA Raid drivers during reinstallation .I believe that the dell system was originally shipped with Windows XP or Vista Operating system which has SATA drivers for SATA hdd. Since windows 2000 Operating system does not have SATA drivers hence unable to recognised hdd.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
Upgrade Hard drive
If you open the case and you can see the seta plugs then yes you should be able to install a seta drive. Since the settings are in bios and seta is becoming more of a norm I would assume you will be able to do this with minimal effort. Remember to look at your power supply leads to make sure you have the appropriate plugs. if not you can get an adaptor if one is not supplied with the drive.
Dec 23, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
383 people viewed this question
Alun Cox
