Question about Maytag Neptune MDE5500AY Electric Dryer
Squeeking in lower dryer
I have the MCE8000AYW drying center. The one with the drying cabinet on top. My dryer is only 2 years old. I am sure it is the roller. It starts sqeeking after the dryer has been on for a few minutes. So how do I access the roller to see what the problem is ?
  • Anonymous Nov 18, 2007
    I am having this same problem. I was told that it is has something to do with the balls in the dryer being worn?
  • blw169 Jan 18, 2008
    I have had the same problem and it was my rollers. The unfortunate thing I am replacing them for the second time in one year. The repairman said the dryer can not handle the same size of load as the Neptune washer can. I have been doing smaller loads but am still having the same problem.
It's probably the idler on the belt that is squeeking not the rollers. If it is the roller the squeek will change with load, the idler generaly is time.
Posted on Dec 27, 2007
    Problem Solver:
  • 19 Answers
Remove the rear panel. unplug dryer before doing anything
Posted on Nov 09, 2007
May tag mce8000ayw start button doesn't work.
no you need to replace the hole thing whach is called Console W/membrane Pad part number 31001658
it may cost about 200.00
Jan 30, 2013 | Dryers
My dryer starts to squek real loud when it is running
The source of this noise is usualy the dryer drum drive belt.
  • Unplug the electrical cord before replacing the dryer belt.
  • 2
    Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
  • 3
    Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.
  • 4
    Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.
  • 5
    Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
  • 6
    Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.
  • 7
    Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.
  • 8
    Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
  • 9
    Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
  • 10
    Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.
  • 11
    Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
  • 12
    Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
  • Dec 28, 2010 | Hotpoint Dryers
    Dryer makes squeeking sound when running
    you need to replace the rollers an idler an belt,,,this will stop your if need help...
    May 10, 2010 | Dryers
    Maytag mce8000ayw start button won't work
    your starter button needs checked at least but most likely replacded
    Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
    Gaining access to dryer
    open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
    Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
    Dryer makes noise like a bird chirpping.
    You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
    Squeeking noise when drying
    you have a whirlpool made kenmore dryer , there are 3 moving parts that can be making this noise , the belt tensioner and 2 wheels that the drum rolls on .
    to get to these parts you go into the front of the unit. start by removing the 2 screws on the top where the lint screen inserts. then get a flat screwdriver to pry the top of the dryer away from the door panel it should have clips holding it down on both sides of the front.
    after that you can see the drum with the top open like a hood of a car , look inside there are 2 screws holding each corner of the front of the dryer , they are 5/16 hex heads , remove these screws and the entire front door panel will come loose , pull the panel upward to release the lower clips holding it.
    Now that this panel is removed look under the drum to see how the belt is held so you can put it back correctly , after removing the belt pull the dr om out and you will see the wheels , you can use motor oil to oil the center of the wheels and the belt tensioner. to get the drum back in set it on the wheels and roll it untill it falls into place and reassemble the rest if you have any other questions let me know and tell me how it works out.
    Jan 07, 2009 | Dryers
    Squeeky Noise
    Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
    Nov 22, 2008 | Maytag MDE4806 Electric Dryer
    Maytag Neptune Drying Center MCE8000AYW
    Email me a response to and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
    Please rate this solution "fix-ya" if it seems to satisfy your question.
    Apr 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
    Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
    Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
    Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
    Maytag Neptune MDE5500AY Electric Dryer Logo
    233 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
