Question about Compaq Presario CQ60-220US PC Laptop
Not getting icons
Hii am unable to open desktop icons.and also not getting any thing like strat menu and its just showing only screen and responding to anything..can u help me.
How to add icons to desktop ?
Assuming you are on Windows 10... if right click on the desktop in a place where there are no icons, you will get a menu.
If you are showing no icons on your screen at all, hover over the View option. A sub-menu will show. make sure that "Show Desktop Icons" is checked.
If you are trying to have the common desktop icons displayed of "Computer", "User Filed", "Network", etc...
the bottom entry on the menu says, "Personalize..."
Click on that, click on "Themes" on the left, click on "Desktop Icon Settings" on the right, then click the check box for every icon you want on the dialog that comes up, click Apply and OK as needed to exit the settings.
If you are on a different version of Windows, the instructions are very similar, you may have to scout around a bit to find how they work in an older version of Windows.
Aug 28, 2017 | Computers & Internet
No icons showing on desktop. Don't know what i have done. Can you help please to restore them
Right click on the screen. Arrange Icons By (Up Top)
Drop down side menu, click- Show Desktop Icons.
Apr 08, 2013 | Computers & Internet
Icons are missing from computer screen
A.
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
B. To re-create the Show desktop icon yourself, follow these steps:
  1. Click Start, click Run, type notepad in the Open box, and then click OK.
  2. Carefully copy and then paste the following text into the Notepad window:[Shell]
    Command=2
    IconFile=explorer.exe,3
    [Taskbar]
    Command=ToggleDesktop
  3. On the File menu, click Save As, and then save the file to your desktop as "Show desktop.scf". TheShow desktop icon is created on your desktop.
  4. Click and then drag the Show desktop icon to your Quick Launch toolbar.
Feb 05, 2012 | Microsoft Windows XP Home Edition
A simple free program that can hide/restore icons on my desktop
Hi hugh hinds....
Try this easy solution to your problem
Please take time to rate me
Hiding Desktop Icons in Windows XPWith a good choice of wallpaper, your computer desktop can add an attractive, even artistic, element to your home or office. Eye-catching desktop wallpaper can be as decorative in its way as a painting or other wall hanging.
If you value the aesthetic potential of your desktop, you might like to enhance it even further by hiding the desktop icons.
Hiding or showing your desktop icons in Windows XP is a simple, two-click procedure.
To hide desktop icons:
  1. Right-click on the desktop and open the "Arrange Icons By" sub-menu.
  2. In the sub-menu, click "Show Desktop Icons" to uncheck it.
The icons should disappear to leave a clean, uncluttered desktop. To show desktop icons again, repeat the above procedure. When the icons are hidden, clicking on "Show Desktop Icons" will enable the option and the icons will reappear.
1...Right-click on the desktop and open the "Arrange Icons By" sub-menu.
2...In the sub-menu, click "Show Desktop Icons" to uncheck it.
Aug 23, 2011 | Computers & Internet
I mistakenly put too many items on the desktop and it's unable to display
Try:
- moving some of the things off of your desktop, into a folder elsewhere on your computer
then
- Hit command-J at the desktop (or view > show view options) and at the "Arrange By" menu, choose "Name". This will make sure that everything comes back on to your desktop in an orderly fashion if some of the icons are pushed out of the way.
Sep 27, 2010 | Apple iMac G4 Desktop
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    My computer keeps showing me this thing where i have to type in a password to keep using the computer and i want it to stop can some on help me
    Here's the steps on how to disable the password in your computer:
    In Windows Desktop Screen
    1. Go to Start Menu
    2. Go to Control Panel
    3. Open User Accounts Icon
    4. Click your Account Name
    5. Choose Remove password
    6. Type your current password
    7. Then click the remove password button
    8. Then close the User Accounts window
    9. To take effect restart your computer
    Also check if there is a password in Screen Saver
    1. In your desktop screen right click (don't point your mouse pointer in any icon)
    2. Choose Properties
    3. Go to Screen Saver tab
    4. Remove the check in checkbox from On resume, password protect
    5. Click Apply
    6. Click Ok
    That's all. Goodluck
    Jan 16, 2010 | Computers & Internet
    My calendar program is missing..
    IN MENU--> SELECT BLACKBERRY LOGO BUTTON--> SELECT SHOW ALL.
    1.To hide a Home screen icon, complete the following steps: Select an icon on the Home screen of the BlackBerry smartphone. Press the Menu key.
    Click Hide Icon.
    2.To show a hidden icon on the Home screen, complete the following steps:
    Press the Menu key. Click Show All.
    3.After the Show All option has been selected, to show a hidden icon, complete the following steps:
    Select the transparent icon on the Home screen that you want to make visible.
    Press the Menu key.Cancel the Hide Icon selection.
    4.If not able to find Install Blackberry desktop Manager ...Take Backup.. reinstall the application from application loader in Blackberry Desktop Manager
    Aug 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
    Icons and start upmenu bar absent
    explorer.exe is what displays the icons and the startup bar on the screen so try opening explorer.exe from the task manager. Or if it is already running close it and then reopen it.
    Jun 08, 2009 | Computers & Internet
    Trying to restore desktop icons to screen
    Go to the folder where the program is located and right click on the launching icon and send it to your desktop.
    Aug 14, 2008 | Computers & Internet
    Compaq Presario CQ60-220US PC Laptop Logo
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
