Question about Yamaha RX-V661 Receiver
No picture I have no picture through any of my hdmi inputs no matter what I use, Cable box, dvd etc, Just sound only, any ideas?
2 Suggested Answers
mlapres
  • 757 Answers
SOURCE: no picture on my yamaha rx-v661 receiver
Connect to your HDMI out from the receiver to your television.
Posted on Jun 18, 2009
Why did I lose the video signal from the receiver to the TV?
I assume you have tried both hdmi cables from box to tv. If both works good.Cconnect to amp. Connect cable box also on other hdmi inputs like bd, dvd, etc to make sure the spesific port is not faulty. If still no picture try to lower hdmi video display on cable box. You amp may not be able to display the higher resolution.
May 06, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
My green light comes on but no picture
Sounds like tv is on wrong input. Be sure HDMI wire or cable input is connected to tv. Look at which input it is on. ( like HDMI 1. Or cable etc. take tv remote (with cable box on ) press input / video button and arrow down to different inputs ( slowly ) until the right input is detected or simply go to the right input you noticed the cable was connected to. Different inputs are there for different sources of connections like DVD. Games. Etc. each work like its own tv channel. Good luck.most times this happens when you are watching tv and press the TV. channel button which will take you to a different tv mode
Aug 10, 2014 | Sanyo DP42746 42 in. Plasma Television
No picture on my yamaha rx-v661 receiver
Jun 04, 2009 | Yamaha RX-V661 Receiver
LG 42LG5 hdmi not working
Have you tried another HDMI cable? The cable may be bad. However, if this is not the case and this is happening across mutliple devices(cable box, dvd player, etc) then you might have a bad HDMI input on your TV. Does this happen on all HDMI inputs on your TV? If you can safely rule out your other devices and the cable itself then you've got a main board problem and would need to get it replaced.
Feb 12, 2009 | LG 42LC2D 42 in. LCD HDTV
No video with HDMI port
try 2 things, first use the rgb cables or video (yellow) cable and plug it into the tv using one of the imports..(vid 1,2,3 etc...) and see if that works. then check to see if you get a picture by not using the cable box, by pass it and connect it connect it in the uhv channel. also make sure you have it on the right input of the tv (meaning scroll through the input button on your remote to find the picture...i've done this a million times). still no picture try your dvd player input and if you have a vhs input see if that works. if it is the hdmi input...to be honest it's expensive and a pain to replace...
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
smeags
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Rca hdtv m50wh754s
You need a audio cable for sound. HDMI cable is only for picture. I use the comp 1 plugs myself, better picture. I found with my TV that the HDMI cable is only good if you have a digital box for it. You can also use the plug to hook your computer to off your graphics card and watch downloaded movies on.
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Yamaha RX-V661 Receiver Logo
73 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
