Question about Refrigerators
Cooling coils in freezer icing up
I believe the defrost timer or heater not working. How do I determine which one it is
  • captainb6 Jun 05, 2009
    How can I test the heater? if I remove it can I apply 110 current to test or is there an ohm value I could test for. How can I test the timer?
  • 15,935 Answers
Testing the defrost timer:
The first thing you will have to do is turn off the breaker that supplies power to the refrigerator or unplug it from the wall outlet. Either way will suffice, as long as you do not try working on your refrigerator while it is powered.
Find the defrost timer. Depending on the make and model of your refrigerator, it may be found in one of the following areas:
Behind the front grill in the freezer
Behind the cover plate in the freezer
Behind the freezer near the compressor
Inside the temperature control console
Once you locate the defrost timer, look on the timer and find the advance screw. Turn it clockwise until you hear it click. Turn the power back on to the refrigerator. If the refrigerator was stuck in cool mode previously, this will advance it into defrost mode. Wait for about 30 to 40 minutes and then check it again to see if it advances back into the cooling mode. You will know when it begins cooling again, as the compressor will turn on.
If after 30 to 40 minutes you discover that the defrost timer is not advancing, then turn the power off to the refrigerator and remove the timer. The plug that connects to the timer can only be connected one way, so it's not important to draw a wiring schematic for this job.
If the timer did advance as it was designed to do, then you will now have to test the timer electronically. With the power off to the refrigerator, remove the defrost timer. Take the timer to a clean workspace.
Set your multitester to read ohms. This is usually the RX1 or X1 setting depending on the model of tester. If you look at the defrost timer, there should be four terminals. Find the terminal that is labeled "C" or "3." If the timer is not labeled, look at the connector plug to determine which terminal gets connected to the white wire; that is the common terminal.
Touch one of your tester's probes to the common terminal. Then, touch the other probe to each of the remaining terminals on the timer. As you touch the other terminals, one or two of the terminals (depending on the timer's current setting) should read "zero" and the remaining one or two should read "infinity."
Turn the advance screw again until you hear the click and then reprobe the terminals. This time, the results should be reversed. The terminal(s) that read "zero" earlier should now read "infinity" and the other(s) should now read "zero." It the timer does not pass this test, then it should be replaced. If it does operate correctly, then return it to its position in the refrigerator. The problem with your refrigerator may be caused by another issue like a bad defrost heater or thermostat.
Testing the DEFROST HEATER:
Before you begin to test your defrost heater, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this repair.
  1. Locate your defrost heater. It can be located behind the back panel of the freezer section of your refrigerator, or under the floor of your refrigerator's freezer section. Defrost heaters are commonly located beneath a refrigerator's evaporator coils. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
  2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
  3. Defrost heaters are available in one of three primary types: exposed metal rod, metal rod covered with aluminum tape, or a wire coil inside a glass tube. Each of these three types is tested in exactly the same way.
  4. Before you can test your defrost heater, you have to remove it from your refrigerator. A defrost heater is connected by two wires, and the wires are connected with slip-on connectors. Firmly grasp these connectors and pull them off the terminals. You may need a pair of needle-nosed pliers to help you. Do not pull on the wires themselves.
  5. Use your multitester to test the heater for continuity. Set your multitester to the R X 1 scale. Place the tester's leads on one terminal each. This should produce a reading anywhere in between zero and infinity. If your multitester produces a reading of zero, or a reading of infinity, then your defrost heater should most definitely be replaced. There are many different kinds of elements, and so it is difficult to say what exactly the reading should be for your defrost heater. But it definitely should not be zero or infinity. If it is, replace the mechanism.
Thanks for using FixYa!!
Posted on Jun 05, 2009
  • Refrigerators Master
  • 13,433 Answers
Its probably the heater.
Have a look at this HVAC refrigerator repair video I saw on youtube few days ago, in that case the heater is faulty and you can clearly see it on the video.
So check the heater if it looks good and heats then its not the problem and its the timer most likely. if its obviously faulty as you see on the video then replace the heater.
Posted on Jun 04, 2009
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Aug 21, 2011 | Kenmore Freezers
Water is leaking from freezer to fridge and pilling up in the crisper trays.
The problem is either the drain in the freezer is plugged or the defrost circuit is not working. To determine which is the problem you will need to empty the freezer contents and remove the back panel from the freezer compartment. Behind the panel is the evaporator coil. If it is encased in ice, then the problem is that the defrost circuit has failed. If not, then check the drain and see if it is blocked with debris.
If the defrost circuit has failed, it could either be the defrost heater that is burnt out or the defrost timer/module is defective. You can use a hair dryer to melt the ice and then troubleshoot the defrost problem. If you have a meter, you can check the continuity of the heater, if it is open then the problem is the heater. Otherwise, you need to check the defrost timer or module.
Apr 23, 2011 | Kenmore Top Freezer Refrigerator
Coil in freezer icing up and auto defrost not working.the heat strip at bottom of coil is not going on and ice build up on coil cuts cold air supply to refigerated side of refrigerator.is there a sensor...
Your fridge is probably suffering from a defrost circuit failure. One (or possibly more) of the following components has failed: 1) the defrost terminator or sensor, 2) the defrost heating element or 3) the defrost controller / timer. Items 1 & 2 should be found in the freezer compartment - behind the back wall. The 3rd item can often be found in the toe space at the bottom of the fridge - behind a kick plate or some other relatively accessible location.
The operation is as follows: The defrost timer runs constantly and about every 8 hours or so, it switches the power from the compressor and its associated controls (fresh food compartment t-stat, etc.) to the defrost circuit that consists of a heating element and a device called a defrost terminator. Power is applied for about 15 to 20 minutes during which time the defrost heater is energized IF the defrost terminator detects the evaporator coil compartment temperature is cold. When the defrost terminator detects that the heater has warmed the evaporator coil compartment to a temperature of about 50 degrees OR the timer has powered the defrost circuit for 15 to 20 minutes, the defrost circuit / heater de-enrgizes. Even if the heater is hasn't reached 50 degrees in the 15 -20 minutes, the timer switches from the defrost circuit back to the compressor through its controls once again. You'll need to determine if 1) the timer is timing, 2) the timer switch can actually send power to the defrost circuit, 3) the defrost terminator can close when cold - or if it is stuck open, or 4) the heater works.
If you don't know how to work with electrical meters and tools or are not comfortable working in tight spaces (back wall of the freezer) with live electric parts, you should call a repair person. Also, refrigerants are very dangerous. If allowed to escape from the tubing, coils, etc. there is a very real danger of instant frostbite if it comes in contact with your skin. You can be blinded if it contacts your eyes. These above reasons make me believe that this is a pretty complicated DIY type job and really isn't a good one for a beginner to attempt. On the plus side, parts are relatively inexpensive, and a qualified person should be able to quickly diagnose the problem. Labor rates and standard parts markup can bring this repair up into $200 and up range, however.
If / when you do call for service, having the freezer emptied & defrosted already - will save the cost of defrosting time by the repair person.
I hope this was helpful and good luck. Please rate my reply. Thank you.
Apr 08, 2011 | Amana ARS266ZB Side by Side Refrigerator
I have a Westinghouse frostfree rj25m upright fridge/freezer. The freezer is working fine but the refrigerator won't cool. I want to fix it myself as it is an old fridge and really not worth spending $300...
I am not sure if your freezer is working correctly if the fridge compartment is not at the right temperature. The way refrigerators work is that the fridge compartment is indirectly cooled by the freezer. The evaporator coils that cool the freezer, also cool the refrigerator. There is a fan in the freezer section that draws air from the refrigerator and blow them over the coils. The vent to the refrigerator could be blocked by debris or ice build up if the defrost circuit has failed. In order to check, you need to remove the back panel from the freezer section to check the condition of the coils/vent. Also check the fan in the freezer and see if it is operating. If the coil is encased in ice, then the defrost circuit has failed and that needs to be fixed otherwise the freezer will not cool to the correct temperature.
The way the defrost circuit worksis that normally the compressor has power for 8 hours, then the timer cuts power off and sends power to the defrost heater for about 45 minutes. The heater is attached to the coil and warms up the coil to melt the ice. When the coil reaches about 40 deg F, the thermostat which is in series with the heater, opens up cutting off power to the heater. This prevents the freezer from getting too hot. After the 45 minutes are up, the timer switches the power back to the compressor again to restart the 8 hour cooling cycle.
Any of the three components can fail causing you not to get the defrost cycle to work. Typically the timer stops advancing so you either stay in permanent cooling or defrost mode. Or the heater burns out so it can
Mar 13, 2011 | Refrigerators
Freezer working but no cooling in the bottom cabin
There is something blocking the cold air from the freezer from reaching the refrigerator compartment. Since you mentioned frost in the freezer section, I can assume that the defrost circuit has failed. This circuit is made up of a defrost timer/module, heater and thermostat. I can't determine whether you have a defrost timer or module since you did not supply a model number.
What you need to do is to unplug the refrigerator, empty the freezer and remove the panel in the freezer section. This panel will give you access to the evaporator motor/fan, the evaporator coil and the defrost heater. Take a hair dryer and use that to melt the ice. Make sure that you monitor the drip pan regularly as you melt the ice since it will fill up with water and you will need to empty it regularly.
Once you get the coil clear of ice, you should see a heating element, it either lookes like a black wire that is attached to the evaporator coil, or it could look like a glass tube with a filament inside. If you have a meter you can determine whether the heating element is working. If the meter resistance setting show it as open, then you will need to replace the heating element. If the element is good, then you will need to check the defrost timer to see if it is turning the cam to periodically run the defrost mode.
If you do not have the ability to troubleshoot the defrost circuit, then call a service company. You can put the refrigerator back together and it should be able to cool the refrigerator compartment, until the service person and fix the problem.
Hope this helps you.
Jul 23, 2010 | Frigidaire Refrigerators
Not freezing
Either the defrost circuit has failed or the refrigerant is low - my money is on the defrost circuit.
Most defrost circuits have three main parts:
1) defrost electric heating coil
2) defrost terminator
3) defrost timer.
The heating coil and terminator are in the freezer compartment - behind a protective panel. The heater is usually piggy-backed on the freezer coil and the terminator is in contact with the freezer coil to detect its temperature. The defrost timer is a simple assembly of a clock motor with switch contacts that can be located anywhere the manufacturer desires. The timer turns on or enables the defrost circuit every 8 or so hours for up to 30 minutes give or take.
When the timer has enabled the defrost cycle, the cooling mode ceases; the compressor shuts off and power is sent through the terminator to the heater. The heater warms and melts any ice build up on the freezer coil. The water drips to a pan and flows down the tube to a pan under the fridge - where it is evaporated off. The heater warms the freezer coil until either a) the timer returns to cooling mode or b) the terminator senses a preset rising temperature on the freezer coil. Once either condition is present, power is interupted and heating stops. The compressor is energized through the adjustable thermostat in your fridge. Since it is warm, the compressor turns on and cooling begins.
If any of the components listed above (1,2 or 3) have failed, the defrost cycle never warms the freezer coil and the ice never melts to clear the freezer coil as intended. Air can not be circulated through the freezer coil since it is choked with ice, so even though the compressor runs, the fridge and freezer spaces never get colder. The adjustable thermostat never sees the temperature you've set so the compressor never shuts off.
Water dripping in the fridge is melting ice from the freezer space - as the freezer is not getting colder - only the protected space around the freezer coil is.
To fix this, you'll have to get the service manual or schematics for the fridge to determine where the parts are located and do some troubleshooting with a multimeter after disassembling the freezer compartment and wherever else to access the timer if needed. This is not a good first appliance repair job for a DIYer due to the danger of refrigerant and testing live electrical parts in closed in spaces.
I hope this helps.
May 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Defrost tube doesn't drain water and ice form under crisper trays This is a bottom freezer - drain tube is clean and I need to melt the ice every two weeks
This sounds like a problem with the self-defrost feature of the fridge. The three major components of most self defrosting freezers are: 1) defrost heater coil, 2) defrost terminator 3) defrost timer. The defrost's electric heater coil & terminator (a simple thermal sensor / switch) are in the freezer compartment in *very* close proximity to the freezer coil for the refrigerant (all of these components are usually hidden behind a protective panel) or in direct contact with the freezer coil (as is the case for the defrost terminator) The defrost timer assembly consists of a small clock motor and relay contact points. This assembly can be located anywhere the manufacturer desires.
If the timer motor has failed, or if the contact points in the assembly have shorted or failed in one position or the other - the defrost cycle will be stuck in one position (either cooling or defrosting) or the other. If the heater coil has failed, the rest of the defrost system is probably working ok, but the heater coil will fail to warm up to melt ice build up. The defrost terminator simply tells the the defroster that the cooling coil has reached a temperature high enough to have allowed the ice to melt off of it and drip into the pan & tube. If it has failed it could be telling the defrost system there is no ice built up.
The parts for this job aren't very expensive, and you can fix it yourself *IF* you have some know how, a bit of an electrical background (know how to use a meter and understand electricity) and can disassemble / reassemble the freezer area without damaging the refrigerant lines. You could buy all the parts and replace each, one by one until it starts working again, but that would be a bit expensive. A repairman coming out to do the repair might be even more though. You'll need to get schematics or the service manual for the particular Sub Zero model (probably the serial number, too) to determine the exact locations of the components and follow any troubleshooting steps if provided.
Don't choose this repair as your first appliance repair job though - it is more involved and dangerous than most others due to frostbite hazards of the refrigerant (if allowed to escape) and electric shock.
May 20, 2010 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerator is not cold,freezer is frosting up
Defrost system failure is correct. It could be the evaporator fan, timer, heater. You can manually defrost with a hair dryer which will give you a couple of days until a service tech can determine which part has failed. Remember, there is a lot of ice behind the freezer back wall around the cooling coils. You can only see the tip of the iceburg.
Jan 22, 2009 | Kenmore Refrigerators
Magic Chef RB19KA-4A not cooling. Compressor is running as I can observe frost on the copper tubing. Condensor coils were cleaned off of dust but overnight the freezer temp only got down to 45 deg F. Any...
It was determined to be a malfunctioning defrost timer. The freezer box bottom was removed (not an easy thing to do) and the coils found to be a solid block of ice. The timer would not start the defrost heater, hence the freeze up. The timer was replaced and the chill box is back in action.
Jul 22, 2008 | Magic Chef Refrigerators
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
