Question about Royal Sovereign ARP-3012 Air Conditioner
My Royal SovereignARP-3012 lower blower fan wheel broke
My Royal SovereignARP-3012 lower blower fan broke into pieces. Parts of the blower blades shot out of the exhaust port during use. How can I replace the blower wheel? The whole assemly looks very difficult to disassemble. Is there a trick to getting to the lower blower fan wheel or does the whole unit have to be taken apart?
This is a difficult repair and no easy cake at all. The one internal part you can order from Royal Sovereign is the lower blower wheel. Perhaps this is because it breaks easily. Begin by draining the unit by removing the rubber plug at lower left. Remove 14 (count them) from the back. Remove additional positioning screws that hold the case side to the metal frame. Take out the two screws on the underside of the outer casing. Unclip the plastic tie that holds a temperature sensor to the rear radiator, and remove the the sensor gently. Spread the casing gently apart and push it away from the chassis a few inches. Reach into the front and unplug the three electronic connectors that link the display panel to the chassis. Note that the two leads that go to the lower part of the chassis go into positions 1 and 3 - the middle connector is not used. Now remove the casing entirely. Take a photo on all sides for reference and get some masking tape ready. You will see an upper blower casing and a lower blower casing, around which are arranged the condenser and two radiators, held in place by four press-formed metal chassis frames and two plastic chassis supports. Do not proceed until you mark where all the screws into the metal supports go. Failure to do this may end up with putting chassis support screws into holes meant for the back panel, making it impossible to reassemble the outer casing. Remove the grounding wire on the right side facing the rear. Tape the screws to the chassis part and note the color of the leads. Mark the location of the screw so you do not put it in wrong place on re-assembly. Do the same with the double green and yellow wires connected to the other side. Disassemble the bracket holding the white metal electrical condenser, noting carefully how the bracket is designed to clamp the condenser in place. Remove all the screws holding all four corner chassis supports, and mark exactly where the screws go. Stick these screws to a piece of tape and label it. Remove all screws holding the upper plastic chassis frame, marking screw locations carefully. Note that some of these screws hold the upper blower casing in place. Stick these screws to another piece of tape and label it. Working from the rear, and using a long phillips head screwdriver, remove two screws that hold the base of the upper blower assembly. Check gently to see if the assembly is now loosened and can be lifted but do not lift it yet. Remove any other screws that impede. Remove the uper chassis support carefully. This is a tricky move, take your time. Remove the tape that holds wiring on the middle plastic chassis support member and put it somewhere you can get it again, you will need it on reassembly. Once the upper blower assembly is removable, lift it EXACTLY vertically to clear the cleats at the base, then carefully rotate it towards you and place it upside down in front of the unit. There is just enough wire to allow you to do this. Remove and tape screws as needed to liberate the middle chassis support member. Remove and tape the two screws that hold the lower blower casing to the deck chassis support. This is where it gets tricky. Remove the middle chassis support but be very careful to support the upper radiator as you do so. Remove and record the location of any other screws that hold the lower blower casing. Tip the upper radiator as little as possible to allow the lower blower casing to be lifted up out of the chassis floor, and out to the side. tis is a difficult move and it is easy to damage the fins of the radiators. Remove the front of the lower blower casing, and remove the blown-up old wheel. Put the new blower wheel onto the motor shaft and make DAMN sure the nut is on tight. Otherwise the wheel will slowly travel up the shaft, rub against the radiator in front and you will have to do it all over again. Reassemble in reverse order. When you re-connect the wiring of the outer casing, be sure to connect the lower wires in front into positions 1 and 3, leaving the center blade open. You will be glad you recorded the exact location of every screw, trust me. It took me seven days to figure this out, even after worming out the service manual and an exploded view from the company (both useless for this repair except for debugging misplaced electrical connections). Easy cake indeed.
Posted on Jun 25, 2010
  • Russwig Sep 19, 2010
    I found this guide very helpful in replacing the lower fan on my ARP-3014. Took me about 4 hours to replace the squirrel-cage. The most challenging part was getting the middle plastic support out. You have to lift the upper radiator out of the middle support being careful not to bend or kink any of the tubes that connect it to the compressor. At the same time you slide the middle support away from the lower fan exhaust port and over the compressor then you have to tilt the lower fan box away from its radiator while angling the middle support up and over the lower exhaust port in order to free it. An extra pair of hands would be helpful.
    Take your time. Pay attention. I think it is best to do it all in one shot as you are less likely to forget where things go on re-assembly.
    RussWig
Order the Lower Blower Wheel for $15 from the link,
http://www.royalfulfillmentcorp.com/StoreBox/pacparts/211ca0001a.htm
open the cover and replace it. easy cake!
Posted on Jun 30, 2009
Royal sovereign portable ac.......removed center screw from broken blower wheel, but it won't slide off and no other screws visible.....is it attached somewhere else?
Posted on Aug 26, 2017
Where to buy replacement fan blades
everywhere Christine!
  • replacement fan blades ' eBay www.ebay.ca > Search > replacement fan blades Find great deals on eBay for replacement fan blades and replacement ceiling fan blades. Shop with confidence.
  • Replacement Fan Blades - Plastic & Aluminum Fan Blades ... https://www.grainger.com/category/fan-blades-and-propellers/hvac... Keep air circulating with replacement fan blades and propellers from Grainger. Get what you need to renew or repair broken fans, condensers and air circulators.
  • Amazon.com: replacement fan blades: Tools & Home Improvement www.amazon.com > Search > replacement fan blades Online shopping from a great selection at Tools & Home Improvement Store.
  • Fan Blades & Arms - Ceiling Fan Accessories - Ceiling Fans ... www.homedepot.com > ... > Ceiling Fan Accessories Shop our selection of Fan Blades & Arms in the Lighting & Ceiling Fans Department at The Home Depot.
  • Aluminum Fan Blades - GlobalIndustrial.com www.globalindustrial.com > HVAC/R & Fans Shop for Aluminum Fan Blades in Replacement Fan Blades & Blower Wheels. Global Industrial is a Leading Distributor of HVAC/R & Fans supplies.
  • Aluminum Fan Blades - www.globalindustrial.ca www.globalindustrial.ca/c/hvac/parts/fan-blades Shop for Aluminum Fan Blades in Replacement Fan Blades & Blower Wheels. Global Industrial is a Leading Distributor of HVAC/R & Fans supplies.
  • Replacement Fan Blades - MSCDirect.com www.mscdirect.com > ... > Fans > Fan Accessories & Replacement Blades Discover Fan Accessories & Replacement Blades and other Fans at MSC Industrial Supply. Over 1 million products that ship and deliver fast.
  • ceiling fan blades ' eBay www.ebay.ca > Search > ceiling fan blades Find great deals on eBay for ceiling fan blades and ceiling fan replacement blades. Shop with confidence.
  • Ceiling Fan Blades Replacement - Price Comparison - Canada www.shopbot.ca/ceiling-fan-blades-replacement/price/canada/593664 Ceiling Fan Blades Replacement - Find the Lowest Prices in Canada. Shop Smart with Reviews, Advice and Prices. Shopbot is Canada's Favorite Price Comparison Site!
  • Ceiling Fan Blades ' Replacement Fan Blades ' ATG Stores www.atgstores.com > ... > Fans > Ceiling Fan Parts & Accessories Shop ceiling fan blades & replacement fan blades at ATGStores.com, a Lowe's store. We carry top brands including Monte Carlo, Hunter Fan, & Fanimation.
  • Feb 18, 2016 | Dryers
    Amcor model PLM14000 E INTAKE BLOWER WHEEL NEEDED
    All I could find was a Owners manual for this unit. If you have the pieces take them to a air conditioner contractor and ask them to find you a generic replacement blower cage.
    You can expect to pay for their time.
    Warning...Some contractors will not provide parts to a customer without charging a service call.
    Jul 11, 2012 | Heating & Cooling
    WERE CAN I GET A COOLING FAN
    royalsovereign.com has a good number of parts available at low prices. You probably just need the blower wheel as they frequently break. It's only $10 + about 6 for shipping.
    Sep 03, 2011 | Royal Sovereign ARP-3012 Air Conditioner
    Crossley Dryer is making a lot of noise. I opened it up to have a look and it seems that the noise is coming from the plastic rotary fan blade. The blade has some play in it where it sits on the motor...
    The blower wheel is replaced as one piece and not the individual blades.
    The part number for the blower wheel is 31001317 it could be picked up from your local appliance parts store,or online at;
    repairclinic.com
    searspartsdirect.com
    apwagner.com
    apdepot.com
    midwestapplianceparts.com
    Gene..OldTech2332
    Aug 20, 2011 | Crosley CDE6000 Electric Dryer
    I have a Goodman GMPN furnace and the motor that runs the twin blowers has quit. How do I take it out and replace it?
    If you mean the blower wheel, I wonder how you diagnosed this problem so you were 100% sure the motor is bad. I recommend to make sure of the diagnosis before spending to buy parts.
    The blower wheel is shaped like a twin blade. But it's only one wheel.
    However, to answer the question; Step one is turn the power off.
    Then; Find the blower housing in the lower compartment on an upflow configuration.
    • Remove 2 screws on the blower housing, on the upper inside of the blower compartment to slide the blower housing out.
    • Disconnect blower motor wiring at the harness and at the control board if connected. You can cut them if you have exact replacement motor and wire nuts.
    • Slide the housing out, turning it on the side that exposes the motor.
    • Remove the 3 mounting screws holding the motor to the housing.
    • Loosen the lock nut holding the fan blade (wheel) to motor shaft.
    • Slide motor and shaft out and away from the fan blade, as they are connected together and cannot be separated. Use penetrating oil SPARINGLY.
    Installation is the reverse of the removal instructions.
    IMPORTANT. Make sure to leave equal space between both sides of fan blade and housing when re-installing the wheel.
    Luck to you. Let me know how that turns out.
    Russ
    myairfixer@gmail.com
    Dec 23, 2010 | Goodman GMS90703BXA Heater
    Have the Royal Sovereign ARP-3012 Air Conditioner for over year. Last week the condenser stopped kicking in. The fan will still work, but when on the cool setting you can hear the condenser try to start,...
    I've had the same problem. I assume that the wind, from outside, blew off the lower blower flan blades. The pieces that came out when the AC kicked shows that the fan blades are only held by one end and stand on a disc like candles on the outer rim of a cake.
    It's the only plausible explanation I could find since there is nothing else that could have gone into the fan the break it.
    Check Eric Olson's solution, it's very well detailed:
    http://www.fixya.com/support/t2319536-royal_sovereignarp_3012_lower_blower_fan
    New fan can be obtained at:
    good luck,
    Alain.
    Aug 26, 2010 | Royal Sovereign ARP-3012 Air Conditioner
    Amana AP148D-RB, Air Conditioner Parts
    Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
    Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
    AC-8000-27 Wheel-blower condenser $21.81
    AC-8000-26 Wheel-blower evaporator $21.81
    I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
    Mar 02, 2010 | Heating & Cooling
    Noise from lower blower or compressor
    pieces broke from condenser cooling fan,can i get new wheel or blower
    Aug 16, 2009 | Royal Sovereign ARP-3012 Air Conditioner
    Royal Sovereign ARP-3012 Air Conditioner Logo
    2,601 people viewed this question
    Top Royal Sovereign Heating & Cooling Experts
    jdthefixer
    Bill Long
    Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
