Win7, 32Bit. All downloads and attachments are declared to be virus infected and deleted. Removed Avast. I am sys admin but system will let me touch Bit Defender
Sounds like a viral infection blocking you from downloading items, in an attempt to stop you removing it. Sometimes, with chrome browser, if you re-install this will clear this issue, to then allow you to download other utilities to cure the viral infection.
I would also try starting the laptop in safe-mode and attempting to download malware utilities there. You may find starting in safe-mode means you are able to download virus removal utilities to try and cure your machine. If you do find this possible, run your scans for infections within safe-mode, they will do a better job of removing any malware. Once you have removed any infections restart the machine and see if the problem is cured.
Here some links to software I recommend scanning with:
Try running these first:
1st rkill - http://www.bleepingcomputer.com/download/rkill/
2nd Combofix - http://www.bleepingcomputer.com/download/combofix/
Then these:
http://www.malwarebytes.org/
http://www.safer-networking.org/dl/
If starting in safe-mode, re-installing your browser etc doesn't improve your ability to download software, perhaps if you have another computer and a pen drive you should try downloading the tools there and transferring them to your troublesome laptop with your pen drive, then proceed as I described above.
If none of that is possible I would take it into your local computer repair store.
SOURCE: How do I unlock mousepad (touch pad) of hp
Just press: FN + F6 please vote for me... thanks .
SOURCE: Hi, i jst bought a new hp laptop probook 4520s
Hello silinsalim, follow these instructions for the "Touchpad," First, click on the "Start Button." "In the (right, area), select to open the Control Panel. Next in the [Hardware and Sound] category. Choose the "Mouse" 'applet.' Next in the "Mouse Properties" (window) click on the "Device Setting" button. Once the window open, click on the "Setting" button. It located, just below the "highlighted" (Name of the device TouchPad. Try out some of the "items listed." Tapping, Virtual Scrolling... "You must click on the "Apply, OK buttons when finished If this information helped? Return and give a "Helpful Rating," please!
Attention! "Manually" Install Driver; select "Update Driver"
Follow all the instructions."
Note: "Restarting the computer will configure system changes in the computer applications to prevent errors and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware."
Thanks, paul7of9
Try running this litte app, sometimes nasty programs just hide your files.
Unhide.
