Question about Canon 730i Laser Printer
Error 0802. old ifax left in memory how do I clear it? refax attempts every 3 minutes. How do I reset to factory settings?
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
Need to clear In Use/Memory light on Canon MX340 printer
Step 1 Press the "Menu" button on the MX340 until "Device Settings" appears on the LCD display.
2.
Press the left or right arrow keys to select "Reset Settings," and then press "OK" to load the Reset Settings menu.
3.
Press the left or right arrow keys to select "All data," and then press "OK" to reset data on the MX340 to factory default settings.
Apr 14, 2015 | Canon PIXMA MX340 Wireless Office...
How do I get more memory for my bernina 730?
Resetting factory settings in some models will only reset the settings of the machine and does not effect the stitch memory.
to clear the stored stitches from memory try the following.
press «clr/del» and left / right arrow
button at the same time
• release both buttons
• leave Memory by pressing the
Left / right button
• Memory is now completely
deleted
You can hold a max of 30 stitches in memory on most models.
Nov 20, 2014 | Bernina Sewing Machines
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so
    3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
I have forgotten my security code. my mobile phone is nokia 2700 classic. serial no is 358241037946264
hello,all you need to do is just to format the phone that is the only option you are left with.
you can try either of the steps below to format your mobile phone or you can as well visit an authorized mobile phone repairer to fix it up for you.
,you can make use of either soft reset,hard reset or factory settings.
Soft Reset
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard Reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice:
It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
press on/off
+ * + 3whenever you forget your security code the only option left to keep making use of the phone is to format it and the steps to take in the formation is to follow them below,
1.MENU
2.SETTINGS
3.RESTORE FACTORY SETTINGS
4.YOU WILL BE ASKED TO ENTER PHONES FACTORY DEFAULT CODE
5.12345 OR 00000
wish you good luck,
take care.
Aug 15, 2010 | Nokia Classic 2700 Cell Phone
How to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
HOW TO FACTORY RESET THE SETTINGS OF AFFICIO 2035 E
Hello sir; You have to print out SMC list before you clear all memory then to reset, the procedure as follow;
1, press "clear mode", "107".then hold down "clear/stop" key.
2 enter 5990 press enter.
3, touch on screen "execute".
after print out go backto clear memory.
4, enter 5801-1
5, follow the list to reset each item.
May 27, 2009 | Ricoh Aficio 450 Copier
Xerox Phaser 3200mfp Memory Issue
Do you have the receipt for the machine? You have a 1 year warranty from Xerox on that machine, Here is the copy and paste from the warranty information on the Xerox website.
Xerox warrants that the Phaser 3200MFP product and its Consumables, Routine Maintenance Items, and Options/Upgrades (related items) will be free from defects in materials and workmanship for the periods set out below:
Product: a period of one (1) year from the date of shipment.
Aug 21, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Will not stop faxing the same document
There should be a memory clear procedure in the menu to stop that.
You will have to reenter the time date, your phone and business name once you clear the memory.
I dont have a book for that particular machine, but faxs do have a memory clear feature for lock ups like that.
Mar 05, 2008 | Panasonic PANAFAX UF-6000 Fax
Canon 730i Laser Printer Logo
136 people viewed this question
old marine
old marine
