My gateway Model MA7 is not booting up with the hard drive and cant get it to use therepair disk I got it to go to the windows setup but it had a error code 7 is what it said
Gateway sx2110 windows 8 formated drive c. now it will not take cds or usb to reinstal. says no boot cds or bad disk. keeps revolving to checking pc and fixing
You might need to go in to BIOS setup and change the boot order to boot from CD/DVD before the hard disk. Same thing for booting from USB. If the boot order is set to the hard disk first and it does not find a bootable partition then that's the error you would get and it might not get past that. I think F2 will let you access that on a Gateway. This is a link to to the Gateway recovery page and it has lots of good info on it. http://gateway-us.custhelp.com/app/answers/detail/a_id/34866/session/L3RpbWUvMTQ5MjA0NTQyMC9zaWQvZlVRWUtZclRhYkZqbl8zSEFEOUdoeFh2MkpUUERRNDhWRU9Od1g4SVNsTWV0QkVSYlBBcjloMmk1WDJWV1I5X2dWa0R1empXcUdsZGNYZTAyMVJKYjFnWUVfa2dyb00ybFFjRlU3VzhFVVluQkNfRzc2SFQ0QXRnJTIxJTIx
Apr 12, 2017 | Gateway Computers & Internet
Why do i boot disk failer
You need to purchase a version of Windows which comes on a CD. Insert the CD in your DVD drive and reboot, and the system setup process will start.
If you had a version of Windows on your old hard drive, get the Key Number off a sticker on your computer and contact Microsoft Customer help; for a small amount of $ they may send you another disk.
Jul 22, 2014 | Gateway Computers & Internet
I have problem with my hard drive, my laptop is a Gateway MA7 I when I turned up it appared a blue screen cheking disk but after this It can't turn on.
power up your laptop from scratch start hitting F8 until an alternate boot screen come up.select boot in safe mode. Once you have booted up restore your system back to a good work date?
Feb 23, 2011 | Computers & Internet
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
Nov 26, 2009 | Gateway MX6453 Notebook
When gateway computer model Ma7 starts it says a read disk error
Usually if you have the install disk for the OS you want it will allow you to wipe the disk during the install
Sep 10, 2009 | Gateway MT6705 Notebook
CANT BOOT FOR REINSTALLATION OF XP, IT SEZ "NTLDR" IS MISSING, ALSO MENTIONS SOMETHING ABOUT THE HARD DRIVE NOT WORKING
If you have the OS disks try a repair first. Run the OS disk and choose the repair option rather than reformatting. That usually fixes ntldr issues.
Apr 30, 2009 | Computers & Internet
I installed a new hard drive in a Gateway 4XL.
See your hard disk Jumper setting it could be wrong change jumper of your hard disk then install the windows.
Mar 07, 2009 | Gateway Profile 4 XLb PC Desktop
Help me to install WinXP in a Gateway Laptop that came with SATA HDD
you have probably already fixed this but maybe others can find this a little helpful. i had to downgrade a gateway ma7 for one of my customers who had lost their recovery cd with vista on it. Their HD had gone bad.
The reason the XP installer says "no HD" is because the the drivers required by the gateways Sata controller (hd controller) are not preloaded on the xp install disc. The only way around this is to download the windows xp compatible sata drivers from gateways website and then slipstream them into a custon windows xp install cd. its actually not as difficult as it sounds. just download the sata driver, a slipstreaming program called nlite.
1 download and install nlite
2 put in your xp install cd, and run nlite, when nlite asks, browse to the i386 folder (your installation files)
3 you will have lots of options to choose from, but for this purpose, choose "add drivers" and select the location of the gateway drivers (c:\cabs\something) i think.
4 finish and burn the cd. then use it to install windows xp.
this little guide isnt step by step, but with a little trial and error you should get by
-Nele, MCSE
Jul 19, 2008 | Computers & Internet
Okay thankx
Hi friend,
so you want to know how to partition the hard disk. there are many software are available to partition the hard disk. you have the windows operating system cd. there you can partition your hard disk.now i tell you the step by step method to partition the hard disk with windows operating system cd installation.
  1. insert the cd into the cd drive.
  2. press the F8 key while the computer before the beep sound comes.
  3. choose boot device to boot first, now choose the cd drive to first to boot.
  4. it enters into the setup of the windows.
  5. after entering into the setup it ask you to copy the windows directory into which drive.
  6. after that option you can select the drive and format the hard disk partition the what type drive you want and how much space you want in the selected drive.
ask me if you cant do it and inform to fixya.com
bye friend.
Jun 21, 2008 | HP Pavilion dv6000z Notebook
Windows Setup cant find hard disk ?????????????
Does the BIOS on your system see the drive and show it's model information? Is this the only drive on the system? If the answer is yes for both, then you can download free utilities from the web to wipe the drive clean. This will result in the loss of all existing data on your drive. You can search for "Wipe Disk" and will get several hits for free software. Once you have cleaned the drive, try instlling XP. If the BIOS does not see your drive, the XP can't see it. You may want to try other SATA ports on your motherboard, or try changing the IDE configuration in the BIOS. Let me know if this works.
Aug 29, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Computers & Internet Logo
748 people viewed this question
David Payne
David Payne
