Question about Maytag MSD2656G Side by Side Refrigerator
Maytag msd2957ae, refrigerator is not cool - Maytag MSD2656G Side by Side Refrigerator
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: my maytag model msd2957ae water is dispensing by
If it continues to run after using , you need to replace the dispensor pad , pt # 666289 . If it dispenses anytime , not , after using , replace the water inlet valve , behind the refrig , where the wall water line connects to on the refrig .
Posted on Nov 13, 2009
Macmarkus
  • 2605 Answers
SOURCE: Maytag refrigerator isn't cooling
Hi ****, Based on the discription you've provided it sounds like either a faulty start relay or the compressor is seized. If you have a multi- meter you can check the compressor to see if the windings are ok. Unplug the fridge. Remove the panel at the back down at the bottom. This should gain you access to the compressor. On the side of the comp. will be the start relay/overload assembly. Pull off the relay & overload and you'll see 3 pins in the form of a triangle. With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin. You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms. On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good ! If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit. This will start it if it's not seized also known as a "locked rotor".. You can find them at most brick & mortar appliance parts locations or on-line vendors. The package contains info on how to connect it. If that doesn't yield any results moving forward, let me know we'll go from there. **I suggest you phone Whirlpool customer support first though ( they own Maytag ) as they recently had a massive recall regarding the starting device of many compressor's and you may find your's to be included therefore have it repaired at no cost.** they will know by your model and serial number or if that isn't clear the number on the compressor. Good Luck Thanks for visiting "fixya", please take a second to rate my solution and leave a comment/testimony to it's helpfulness. macmarkus :)
Posted on May 02, 2010
Maytag MFD2560HEW refrigerator. Refrigeration section not cooling... Freezer appears to be fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 15, 2011 | Maytag MFD2560HES Bottom Freezer French...
My refrigerator has stopped cooling - though my freezer is still cooling just fine. Please help!! Model # is Maytag MFD2561KES
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 01, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
Refrigerator not cooling it is a maytag with freeser at the bottom freeser is maintaining temp
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Aug 02, 2010 | Maytag MFD2560HES Bottom Freezer French...
May 02, 2010 | Maytag MZD2766GES Side by Side...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
My maytag model msd2957ae water is dispensing by itself
sounds like the water solenoid is stuck open.
Nov 13, 2009 | Refrigerators
Refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 28, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Maytag refridgerator not cooling
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Maytag side by side fridge.
My Maytag side by side is 7 years old. Bar between fridge and freezer just began getting very, very hot also? What can we do to repair? Does the condenser fan motor need to be replaced?
Oct 23, 2007 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
236 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
