Model MFC 8460N There is a loud clicking nooise coming from the paper tray then it says paper jam. The tray then has to be filled to the top in order to rint. The clicking continues but it will print.
Thank you for getting back with me. I thought this was a solution website, not a sales website. I will pursue another avenue to get the solution to my printer problem.
Posted on Jun 05, 2009
We have a MFC8460N, when we go to make copies there is a loud clicking noise & it says 'paper jam' & will not make copies
Hi
The clicking sound comes from the paper tray. The problem is that the paper gets jammed when it feeds the paper and it will sound clicking because the printer cannot pick up the paper at the tray.
What you will do is to put bond paper into a tray but the paper head should not be so tighten. Just put the bond paper with the top paper in upward position.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 02, 2011 | Brother MFC-8460N All-In-One Printer
Paper tray problem - full of paper but can't pull up paper and display says tray empty also loud clicking noise coming from paper tray
hopefully we can stop problem before it gets worse, take paper tray all the way out of machine, look at back of tray where paper stop is, move to LTR make sure arrow is pointing directly to it, not before od after, then lock it in, the pictograhm has a pad lock symbol to show locked and unlocked. if the blue tape is still in paper tray, remove it. hopefully no damage done to pick up assembly, or gears on paper tray
Sep 25, 2010 | Brother MFC-8460N All-In-One Printer
Paper feeding problem with MFC-8670
Try REMOVING the white caked up paper dust from the pickup roller located at the front of the paper tray. Next, clean the pickup roller with either 409 or Fantastic all purpose holdhold cleaner using a Q-Tip or a rag.
May 10, 2010 | Brother MFC-8460N Laser Printer
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Will not pick up paper. It makes a loud clicking
Check the tab at the end of the paper tray, needs to be right on the arrow for your paper size, too tight won't allow picking up paper. If OK, take out paper tray and set on a table, the gear closest to the table has a flat area that needs to be level with the bottom of the tray or the table. If slanted up you need to bend the paper lifter bar under the front edge of the paper so that the gear is level again.
Jan 25, 2010 | Brother MFC-8460N All-In-One Printer
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460N Paper Jam
paper jams alway in the same spot- just as it's about to exit the bottom tray
Feb 08, 2008 | Brother MFC-8460N All-In-One Printer
210 people viewed this question
k24674
jasbo
jasbo
