Question about Saeco Incanto Sirius Fully Automatic Coffee Maker Stainless/Black
Saeco Incano Sirius brew unit blocked
Hi, I am getting a brew unit blocked fault on my machine and have tried the following (keep in mind that Im an electrical eng.)
-Originally machine would not power up, found bad power switch & bypassed.
- after fixing above, I powerred it up and it began its warm-up. I unplugged it to tidy up the wiring.
- plugged it in and heard a slight pop. Since the good side of the switch was still connected (and the bad side wired through), I figured the switch made the slight pop so I bypassed the swich all together.
-now I get brew unit blocked after every power-up & selftest
the brew unit has been removed and is free to move.
-performed the bypasses to the switches with no brew unit in to see if she would spin but no luck... as far as I can tell it is in home position (N)
-went as far as disconnecting the motor from its circuit board and feeding it with a 9V battery to get it to spin in each direction. This worked well, meaning the motor is good.
-Have not tested the continuity of the switch yet but I will do that next, I have had it for the night
ANY THOUGHTS
  • electroma279 Jun 05, 2009
    I have removed the power board and checked the large capacitor and it checks OK. I noticed the bottom of the board has bubbled but not directly under the capacitor. Could this have been the POP I heard...
    Seems that this may be a bad board now
    Another thing worth noting, the motor does not even attempt to move, it just self tests and goes into blockage fault.
    CPU board does not show signs of damage, and capacitors look ok visually
    President:
  • 1,618 Answers
It is possible that the problem is in the CPU board, check the board, and the capacitor next to the pump.
Posted on Jun 04, 2009
My Saeco incanto sirius coffee machine started the day with brew group blocked error. I have fiddled and got as far as it grinding beans before saying brew group blocked again. I took it out and now it...
If it stopped working after that incident of reset, could be. Water could have also gotten in the controls. I would use an air compressor and clean out all the alignment areas and switches.
Nov 02, 2013 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
I have the Saeco Incanto Sirius. It makes grinding noises but does not dispense coffee, just hot water.
The grind might be too fine or the grind chamber is blocked, remove brew unit and check the door covering the grind chute to make sure it is clear, or adjust towards coarse about 2 numbers.
Apr 13, 2011 | Saeco Incanto Sirius Espresso Machine
Brew group keeps getting blocked. Machine is 2 years old.
Howe oily are your beans try swithing to a dryer bean. Have you used a degeaser threw the brew group.
Dec 08, 2009 | Saeco Incanto Sirius Fully Automatic...
Saeco S-class Incanto Sirius brew unit stuck
Try running the clean cycle again, that sometimes will help the machine to reset.
Sep 15, 2009 | Saeco Incanto Sirius Fully Automatic...
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Sirius Incanto loud noise
When you power on the machine, can you hear the machine do the self test?
is there a crack sound when the brewing unit is in work?
Aug 01, 2008 | Starbucks Saeco Italia Digital Barista...
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
www.cerinicoffee.com
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Sirius Fully Automatic Coffee Maker Stainless/Black Logo
555 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
