Question about RCA HD61LPW42 61" Rear Projection HDTV
Rca lamp replacement, still no picture, power light still blinks.
I think I have a problem with my ballast, I just got a replacement lamp for my rca hdtv replaced it, but still no picture (but there is sound), sounds like the lamp is struggling to power up. The power indicator light blinks five times, stops and repeats over and over again, it then blinked continuously for about a minute. Does this sound like a ballast problem? or is there some special lamp replacement procedure that i didn't do? What exactly is the function of the ballast and what are the common issues when one needs to be replaced. Any solution would help so much. Thank you!
  • RCA Master
  • 5,138 Answers
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Posted on Dec 30, 2009
  • Darlene Secord Somers Aug 21, 2014
    I also am having the same problem as well. I did notice also that when i use to turn on the tv the first thing i always heard was the fan coming on then the picture would come in shortly after. But all of a sudden now since we replaced the bulb (for the 5th & last time) we do not hear the fan coming on. I refuse to spend any more money on this unit when there are so many more out there on the market that do not require bulbs. We have replaced the bulb in this unit once a year for the last 5 years at almost 200.00 per bulb it's crazy.
Replaced lamp on 52' samsung tv and still no audio or visual.
Posted on Nov 11, 2009
    President:
  • RCA Master
  • 1,779 Answers
I would check all the electrolytic caps in the P/S. The ballast is trying to ignite the lamp but needs a better kick in the _ _ _. You'll probably have to use an ESR checker... Let me know how you do?
Posted on Jun 04, 2009
2 Suggested Answers
SOURCE: replace lamp on 50' rca dlp and still no working.
i just replaced the lamp in rca m61wh185yx1, and the tv is doing the same thing----blink---blink----blink---flashes-steady
what-else could it be
Posted on Feb 21, 2010
My id5220 television power light blinks but no picture or sound
1,the lamp ballast is failing
or the mother board is failing
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 16, 2014 | HP Id5220n 52-inch 720p Dlp Hdtv sliv Lamp...
I installed a new lamp and the tv is still blinking saying the lamp is bad. There is no picture.
its most likely the ballast which is causing the issue. The ballast is what provides the power source to light the lamp. You can get the ballast at www.tvrepairworld.com and they can provide instructions on how to replace the ballast
Mar 31, 2013 | Mitsubishi WD-73733 73" HDTV
I replaced the lamp on my toshiba 42HM66 and that worked for about 2 weeks. I ordered a new lamp and replaced it. Now the lamp light blinks amber and then the power light blinks green at about 30 second...
You will need to check if the output supply going to the lamp is good. If not the ballast will need replacement. That model is actually famous for haveing ballast issues. You can get the replacement ballast from www.tvcircuitboards.com they also assist with installation assistance if you require it.
Nov 07, 2012 | Toshiba 62HM95 62" DLP HDTV
My red light is blinking 3 times, the picture comes on and then shuts it self off and starts blinking. I have replaced the lamp and shut the lamp door correctly.
Hi,It sounds like an issue with the board that powers the lamp it's called the ballast.The ballast has a sensor that it detects when lamp is not responding or if ballast is not able to provide enough power to light it up,that's when you get the lamp indicator.This is the most common failure .When you put a new bulb in sometimes the ballast is not able to power it since it uses more voltage that what it was providing to the old lamp.The ballast is something easy to replace and it's cheaper than the lamp.Have a bless one!
Apr 27, 2010 | Sony KDS-R50XBR1 50" HDTV
Power switch lights up,flashes 5 times,goes out,nothing happens,no picture,no sound
There are quite a few possibilities with the 5 blinking lights:
  • Possibly a bad power supply board (check the lamp first, then troubleshoot further)
  • The lamp is faulty
  • The ballast is weak and unable to ignite the lamp
  • The ballast is faulty
  • The color wheel is not responding
  • The light engine is not responding
  • The lamp is not seated properly, or has not made a connection with the ballast.
Are there any other indications?
Feb 04, 2010 | RCA M50WH185 Television
Replace lamp on 50' rca dlp and still no working.
Before replacing the Ballast I would look at the power-supply and see if you notice any of the electrolytic capacitors tops being bubbled. It is not uncommon for the capacitors to go bad as the lamp draws more current as it ages and fails. If you do see capacity's bubbled, Replace them or have them replaced and the set will probably work fine afterwards.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Dlp 50 inch
sounds like the DM3 isnt powering up the ballast to light the lamp or the ballast may be faulty. i would suggest trouble shooting the DM and ballast voltages.
May 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
No Picture, already replace lamp. model RCA HD50L PW62AYX6
What model set do you have. I also work as a tech at another place that probaly has your troubleshooting guide for your light engine
Jan 17, 2008 | Televison & Video
No picture
replace the lamp and the lamp ballast board using ONLY Sony Parts.lamp A-1606-034B ballast 1-468-798-16 this worked for mine.
Oct 02, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
RCA 50" dlp lamp dead?
There are many different problems with RCA televisions. One could be a color wheel. Another could be a bad ballast. www.Lamp-Replacement.com has a guide and solutions for your RCA lamp 265866 or 270414. The problem is most likely a bad ballast, which is supposed to pre-charge your lamp and ignite it. If you aren't even getting to that stage, you can trace the problem to another component or power supply.
Sep 01, 2007 | Televison & Video
RCA HD61LPW42 61" Rear Projection HDTV Logo
888 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
