Question about Maytag SAV2655A Top Load Washer
Maytag washer sav365zaww
Washer is making a rhytmnic squeaking when in the wash mode. machine is 2 years old.
  • Larrry Jan 01, 2008
    I've got the same problem with the SAV2655AWW: Rhythmic squeak at each agitator advance in wash cycle, yet no problem in spin cycle. At least it still works and hasn't started leaking yet (see epinions.com). That said, I'd still consider fixing it if anybody knew what the problem was.
  • traininguru Mar 20, 2009
    The sav365zaww washer made squeaking sounds and just today made a loud noice and began smoking.
    Filmmaker:
    Uploaded 5 video answers.
  • 30 Answers
LARRY...I HAVE THE SAME MODEL AND THE SAME PROBLEM JUST STARTED FOR THE 3RD TIME. CALLED THE REPAIRMAN THE FIRST TIME, MYSELF THE 2ND. MINE IS A BROKEN(IN TWO) BRAKE PAD. THERE ARE THREE OF THEM. REMOVE 2 SCREWS AT VERY BOTTOM OF WASHER FRONT AND REMOVE PANEL. YOU CAN GET TO THE 2 FRONT PADS FROM THERE ALTHOUGH TIGHT FIT. I ALSO READ THEY SHOULD HAVE CLEAR LITHIUM GREASE ON THEM, ALTHOUGH THIS DOESN'T MAKE SENSE TO ME. GONNA GO DO MINE AGAIN...GOOD LUCK....KHRIS
Posted on Jun 12, 2010
Heavy duty 20 lb..starting to make squeaking noises during agitation only
The bearings in the agitator are worn out and need replacing.
Jun 19, 2018 | Washing Machines
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Front loader washing machine squeaks when the drum turns
Dear friend
I think it might be one of two things. It could be the rubber band around the drum getting worn out. Or the drum could be starting to loosen or rather the screws loosening.
Take contact with an electrician and ask.
all the best
Kolbrun
Jun 07, 2012 | Hotpoint Washing Machines
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
My 15 year old Amana Heavy Duty Washing Machine (top loading) has developed a very bad squeak during the wash cycle.
sorry its the clutch and trasmission its going out either repair or replace the washer my wifes washer started doing the same thing somedays it did fine and others times started squeaking.
Dec 22, 2009 | Washing Machines
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
Squeak on wash cycle
Try some anti-sqeek stuff on the belt, or just rub some soap on the belt.
Jun 29, 2006 | Admiral AW22 Top Load Washer
Maytag SAV2655A Top Load Washer Logo
280 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
