Question about Dell Inspiron E1705 Notebook
Can't add 2 vista computers to Dell wireless printer adapter 3300
I've tried EVERYTHING:
-using local instead of network,
-using TCP/IP mode which pretends to be successful, except when you print to the printer, the printer does not receive it but windows vista pretends as if it has sent the document to it and the printer has printed it successfully!
-using LPR ports
I am an atheist, however, I deeply believe that windows vista is cursed.
  • Dell Master
  • 32,281 Answers
Is the printer a networked printer or is the printer attached to a computer?
Posted on Jun 04, 2009
I have a ricoh sp 3300dn and neet to set the ip for it, can anyone tell me how this is done, you can't do it for the printer like most. rick
Configuring DHCP/BOOTP
To enable or disable DHCP/BOOTP, use one of the following methods:
• Web Image Monitor SP 3300 Series: Select Network Settings >
TCP/IP and select DHCP or BOOTP from the IP Address Assignment
Method list.
Creating a Standard TCP/IP port
1 In Windows XP, click Start > Printers and Faxes.
In Windows 2000/Windows Server 2003, click Start > Settings >
Printers.
In Windows Vista, click Control Panel > Hardware and Sound >
Printers.
2 Click Add a printer or double-click Add printer, and then Next.
3 Click Local printer attached to this computer and then Next.
Make sure that Automatically detect and install my Plug and
Play printer. is not selected.
4 Click Create a new port, select Standard TCP/IP Port from the
Type of port list, and click Next.
5 Click Next.
6 Enter the IP address or DNS name of your network printer and click
Next.
For the port name, a default name will be entered by Windows. You
can change it to a more user-friendly name.
7 Follow the instructions on the screen to complete installation.
Now, you can select your printer from the Print Setup dialogue box.
reply if you need more
timothyvdh@gmail.com
Jul 30, 2009 | Office Equipment & Supplies
Dell 3300 adapter
Let me recap, just one more time.
Your wireless router,
You updated the firmware(most have out dated firmware from sitting in the warehouse)
Broadcast SSID
Using WPA-PSK(TKIP) Security
Mixed mode(b and g, n if available) This is needed for wireless devices to work properly.
Channels 1, 6 or 11. These channels are the channels most wireless devices work on the best(I use channel 11)
Now for the printer. Download and run this patch to completely remove the printer from your computer.
The patch is password protected. The way around the password protected zip file is to open the zip file with Winrar or 7zip(.exe file)
Restart your computer.
After router is done, now setup your wireless print server/printer.
3300 Utility
3300 Firmware
Attach the 3300 to your computer using the USB Cable and insert the 3300 disk. Follow the instructions. It should ask you for the network ID, type of security and password.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Install the drivers, choose network, choose I'm using a wireless print server(if you do not see this, then choose add printer and you should see it then) and follow the instructions.
Thanks for contacting Fixya
Jun 05, 2009 | Dell 3300 Print Server
Unable to install DP G 301 For laser jet 5 printer
0.Follow the manual instructions to configure the Printer Server (tpc/ip), connection toyour local wireless LAN, etc. then, specific for Vista: 1.Vista Start Button 2.Control Panel 3.Printer 4.Add New Printer 5.Select Local Printer 6.Click on "Create new Local Port" and from the menu "Standard TCP/IP Port" 7.Click on "Next" button 8.Menu "Type" select TCP/IP and write the IP address of your Printer Server. UNSELECT "detect printer to..." then press "Next" button 9.If everithing is fine, it must find your printer server. 10.Select your driver ... that's it .... unfortunately I found some problems printing documents: it works till half page then the printer stop and I must cancel manually from the printer the job in order to reset the printer itself.... looking for solutions
Mar 16, 2009 | D-Link Computers & Internet
Lexmark 4227 Plus Matrix Printer on Vista
Operating System Printer Driver Installation Procedure
NOTE: This procedure involves driver installation and port creation using Microsoft's Standard TCP/IP printing.
Step Action Click on Image 1 Click on the Microsoft logo start button. pattlnk_3212007_1551-vistastrtsm.jpg 2 Click on Control Panel. Image 3 Click on Hardware and Sound. NOTE: Classic Mode users can double-click directly on the printer icon. Image
4 Select Add a printer.
Click for Image 5 Network installation
Select Add a network, wireless or Bluetooth printer (for direct IP printing, network print queues - \computernameprintername, etc.)
NOTE: For printers connected via LPT1 (parallel), select Add a Local printer (e.g. IEEE- 1284 compliant printer cable, etc.)
Image 6 Observe Searching for available printers...
Upon completion, select (highlight) your printer, and click Next.
Your printer's IP address will be displayed under the printer description. Use the IP address obtained under Recommended above.
Available Windows Vista Search options:
  • Stop Search - Select this if you can identify your printer prior to search completion.
  • Search Again - If your printer does not appear,determine whether the printer is on the same segment of the networkand confirm successful communication with the printer.
HINT: Windows Vistawill only search the local subnet. If you are confident that theprinter is communicating over the network, select The printer that I want is not listed and try to add the printer's IP address manually.
Image 7 Observe Detecting the TCP/IP Port...
NOTE: Windows will automatically move to the next page when the detection is finished.
Image 8 Observe Detecting the driver model...
NOTE:
Image 9 The Printer name will appear, click Next.
Optional: If youwould like a distinctive printer name and do not want this printer tobe your default (i.e. main) printer, enter a different printer name and deselect Set as the default printer. Image 10 Observe Installing printer... Image 11 Upon completion, a Windows test page will print. You can verify the printer's installation by opening the printer's window.
Feb 23, 2009 | Lexmark 4227 Matrix Printer
Dell 3300 Printer Adapter and Vista
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device.  Assume the printer is connected locally to the machine.
Feb 01, 2009 | Dell Inspiron E1705 Notebook
Printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Jun 12, 2008 | Brother MFC-7820N Printer
Will not connect
If the connection is correct, make sure that the tcp/ip settings on your pc is set to OBTAIN IP AUTOMATICALLY. There might be a STATIC ip set on your adapter.
Mar 13, 2008 | Dell 1450 (D1450U) Wireless Adapter
Internet sharing
Hi, Could be done. On the Dell XP - 1. Activate your Internet Connection Sharing. Go to Control Panel, Click on Network Connections, right click on your Local Area Connection, Properties, Advanced tab, check Allow other network users to connect through this computer's internet connection. In Home networking connection, choose "Local Area Connection", OK; 2. Back to General settings, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address 192.168.0.1, Subnet mask 255.255.255.0, Default gateway 192.168.0.1, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." You have to connect the DellXP with the DellVista using a crossover networking cable. On the Dell Vista- 1. In your Network Connections, right click on your Local Area Connection, Properties, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address 192.168.0.2, Subnet mask 255.255.255.0, Default gateway 192.168.0.1, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." The above method will also work with peer to peer wireless networking. It might also facilitate connection if you enable auto-detect proxy settings in your browser. There are other methods. This is also better explained at Microsoft support Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | Computers & Internet
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Dell Inspiron E1705 Notebook Logo
139 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
