Question about Printronix Line Matrix P5005B Printer
My printronix printer making shadow while printing
    Scholar:
  • 34 Answers
Hammer Phasing Adjustment:
Important: The printer must be printing the Phase pattern of “H’s” when the
Phasing Value is changed, or the New Phasing Value will not be written
into NVRAM. If the value is changed when not printing, the printer will
return to its default phasing value when powered off then back on.
1. Raise the printer cover.
2. Install the ribbon.
3. Load full width (136 column) paper and set the top of form.
4. Power on the printer.
5. If the printer is on-line, press the ON LINE key to place the printer off-line.
“OFFLINE / CONFIG. CONTROL.” displays.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
18. Close the printer cover.
19. Press the ON LINE key to place the printer on-line.
NOTE: If you changed the phasing value, power down the printer, remove
the shuttle cover, and write the new phase value on the aluminum
shuttle casting.
Posted on Jul 07, 2009
    Scholar:
  • 111 Answers
Seems like you need to do a Phasing adjustment. If that doesn't work could be a few different things.
Please give me a call.
Rory Cardenas
Midrange Repair and Parts
3821 W. 127Th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@hotmail.com
AOL IM: RORYMRP
Posted on Jul 29, 2009
2 Suggested Answers
jwr1914
  • 31 Answers
SOURCE: Print result p7005
You have something caught in the hammerbank cover. Sometimes a piece of lint, paper chad or some ribbon fabric will get hung in the holes and need to be cleaned out. Remove the ribbon, open the 'mask' as far as you can and look into the hammerbank area to find and remove the debris. Reload the ribbon and run a test print to see if the problem is solved. If not, the problem will usually be a hammer that is not retracting.
Posted on May 29, 2009
PRINTING SETING
just select your exact phase value and save it
Mar 01, 2014 | Printronix P7005 Matrix Printer
Printronix error b22 decompressed size
flash ic having problem logic crad have to change
Feb 04, 2014 | Printronix P7005/p7010/7205 Ultra Capacity...
Whe i boot up my printer it automaticaly prints out one label with leters on the top left corner and after that every other label i print out comes out with those leters can some one help me asap ...i need...
Sounds like a driver issue that is adding extra characters into the print script. Make sure your printer supports PostScript or PCL. PCL is the most common and works with all printer. PostScript requires a PostScript Chip installed in the printer. Download the latest driver either from the Printronix website or CNET.com
Oct 24, 2013 | Printronix T5000r Label Printer
Can the Printronix P7005 PSA3 print PDF files?
Sounds like your printer may need IPDS, I'll need to see a configuration page from your printer in order to determine whats on it. you can email me it at rcardenas@mrp.to
Apr 09, 2013 | Printronix LineJet® P7005 Printer
Printronix P5215 not printing full columns. I have changed phase settings but still leaving characters from the right margin. Please help
If you are missing columns of print (vertically), the ink is making the hammer frets stick. The shuttle probably needs to be removed and the frets cleaned. This is a common problem.
Apr 19, 2011 | Printronix Line Matrix P5215 Printer
Printronix P5005B printer printing garbage after configuration
If using RS 232 serial communications, verify that host and printer settings match. Baud Rate, Parity,Stop Bits, 7or 8 bit word length. Example 9600,8,n,1
Or make sure it is not in hex dump mode.
Sep 24, 2010 | Printronix Line Matrix P5005B Printer
Print result p7005
Oct 19, 2008 | Printronix P7005 Matrix Printer
Printronix
i have problem in winxp for printer proline sereis 5 printronix line printer driver not match
in custom size
so need for printer driver winxp supported
Sep 18, 2008 | Printronix Line Matrix P5005B Printer
Printronix p5005b line skip problem
yeah I ran into this once, set the printer up to ethernet and not auto switching, i think thats what it was.
Dec 10, 2007 | Printronix Line Matrix P5005B Printer
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
May 30, 2007 | Printronix LaserLine L1524 Printer
Printronix Line Matrix P5005B Printer Logo
646 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
