Question about Frigidaire ATF6000ES Front Load Washer
Drum came loose on Fridgedaire front loader on final spin cycle.
While washing a normal load of clothes in my Fridgedaire front loader that is only 4 years old it starting making a very load banging and clunking noice on the final spin cycle. The door was locked shut and sprung. The drum on the inside was dented in the back all the way around from the stress of no support. This machine has had very little use in the 4 years since it is only my husband and I at home to use it. I guess you get what you pay for. We won't purchase anymore Fridgedaire products.
    President:
  • 1,185 Answers
What was the point of posting this on the site?
The drum has broken loose from the support plate at the rear
You need a new drum and a support plate plus probably an outer shell.
A complaint to the manufacturer may get you a deal on a replacement
Posted on Jun 04, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Drum is loose in machine and swings forward and back. Clothes are still very wet after final spin.
the rear struts have come loose and need re tension this will cause the barrel to come loose due to the barrel not being centered it will not spin at full cycle vortex and leave the cloths some what wet you need to take the top and back covers off and re tension the struts and make sure all 4 springs are well attached..
best of luck
merry christmas
Dec 07, 2010 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
I have a Fridgedaire Gallery front loader, was making a loud banging noise on spin cycle, now the whole drum has dropped! help!
The symptoms that you describe sounds like the spider arms that support the drum are broken. It is a very expensive repair. Get a few estimates, before deciding whether it is worth repairing or replacing. Sorry.
Oct 06, 2010 | Frigidaire ATF6000ES Front Load Washer
I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 05, 2010 | Frigidaire Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Mar 05, 2008 | Washing Machines
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
353 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
