Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Power head not working
Hi thanks for your help. We have a Dyson Stowaway with a DC 20 turbine head "for improved performance on carpets". Our power head is not working. We have pulled it down using the instructions and can't see anything causing the problem. The bristles do not rotate. If we put our hand on the suction point whilst the cover is off, it works. As soon as we put the cover on it doesn't seem to have suction and doesn't work. I'm not sure if there could be something wrong with the seal or if there's something really simple that I've missed. I really would appreciate anyone's suggestions on what could be happening. Cheers, Michelle
There is a gray button next to the red "power on" button that powers the brush unit. If the unit has tripped the reset for some reason it must be reset. This can be done by holding the gray button down for ten seconds while the unit is not running. When you power it up after this reset, the brush unit should run.
Posted on Jun 14, 2009
    Sniper:
  • 53 Answers
There is a belt which drives the brush head. Make sure that is not broken. Also, the pull out on the side of the unit that has the "filter" on it is the on/off for the brush head. Make sure this is pulled out so the brush head can rotate. Last of all, when you put the cover on the unit make sure it is completely flush with the unit and not binding the brush bar in any way.
Posted on Jun 04, 2009
SOURCE:
Head beater not turning fast
Hi, it's Allan at Dyson.
In this case I would suggest this is down to a performance issue. The brushbar is a turbine head and will be powered by the airflow and not a motor.
I would suggest double checking the head itself for any tangles or blockages but make sure that the filters are all washed regularly.
If there is a blockage in the machine itself, then this will naturally cause an issue with performance.
How to remove blockage
If you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
I hope this is helpful.
Best wishes,
Allan
Jan 21, 2016 | Dyson Stowaway DC23 Bagless Canister...
Dc 39 canister carpet brush will not turn
on the head there is a round filter type part if that is pushed in the the brushes won't turn. try pulling it out slightly.
Apr 07, 2014 | Dyson DC39 Animal canister vacuum cleaner
I have a dc56, will the new tangle free turbine tool, part No 925068, fit it?
Hi Lyn, it's Jack at Dyson.
DC56, the new Dyson Hard vacuum cleaner, is engineered for quick cleanups on hard floor surfaces - wood, laminate, lino, tile etc. It also converts into a powerful handheld vacuum for dusting tasks around the home and inside the car.
The Dyson Hard is not designed for use on carpeted floors, and we do not manufacture a motorised head for this machine as it lacks the wiring and connections needed to supply current to a motorised head.
Airflow-driven Turbine heads, such as the Tangle-free Turbine tool, are engineered to work with the performance characteristics of our mains-powered vacuum cleaners, and are not compatible with Dyson cordless or handheld vacuums.
However, we do have a range of accessories which are compatible with DC56, and you can find these on our website: http://www.dyson.co.uk/accessories/variant-accessories.aspx?pid=DC56-dyson-hard
Apr 02, 2014 | Dyson DC56 Hard Floor Wet/Dry Bagless...
Dyson turbine head
Hi Kevin, Alec from VacuumSpot here. Unfortunately Dyson don't actually sell individual mechanical components to their turbine heads, so even though it is probably a pretty easy repair you can't get the parts. In this case you will have to buy a complete new head.
May 25, 2013 | Dyson Stowaway DC23 Bagless Canister...
Problem - Dyson Vacuum - Turbine Head DC-23 I have the Dyson Turbine Head DC-23 Vacuum. I love my vacuum. I've had it for 13 months. I have had no problemwith it, until now. Now, every...
I'm sorry to hear you're having difficulties with your DC23's turbine head. If you haven't already got in touch with us directly, I'd encourage you to do so. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue you're experiencing, and will be able to recommend the best course of action. If necessary, we should be able to replace the turbine head under the 5 year warranty, as long as it's been used in accordance with the terms and conditions listed in the user guide.
You can call us free on 1866MYDYSON - or if you email your details to [email protected], someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 07, 2011 | Vacuums
Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
I'm in the USA and looking for a Dyson DC-11 power head replacement. Any ideas?
Hi its Darran at Dyson.
A replacement turbine head can be purchased online direct from Dyson at www.dyson.com/store. The part costs $95.99.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Mar 17, 2010 | Dyson DC11 All Floors Bagless Canister...
Dyson power head stops when on carpets, cleaned brush out, still happens.
As the Turbine head is air driven, you may need to wash the filter and check the rest of the machine for a blockage as a loss of suction will also reduce the performance of the Turbine head.
For the full blockage procedure and filter washing instructions, please visit the Support section of our website at www.dyson.com.
Kind regards
Darran
Jan 31, 2010 | Dyson DC11 All Floors Bagless Canister...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
2,826 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
